Reverse gear - Team Integra Forums - Team Integra
post #1 of 2 (permalink) Old 05-02-2019, 12:42 PM Thread Starter
Reverse gear
Not sure how common it is, but I have a 2000 ls with 140xxx and it sounds AWFUL in reverse. It’s a high pitched buzz that sounds like one of those yellow ball shooters were you pull the lever back a bunch of times to get a big disk spinning and shoot the ball. How much attention does this need? Thanks 🙏🏼
Luke_swins is offline
post #2 of 2 (permalink) Old 05-02-2019, 01:22 PM
Absolute_Yeti's Avatar
I would start by draining the transmission fluid into a clean clear container and check it with a magnet for teeth and other metallic debris. It could be low fluid, could be worn out fluid could be damaged internals. Typically the longer you wait on transmission issues the more irreversible the problems become (no pun intended)
B18b1
Absolute_Yeti is offline
Similar Threads
Transmission slips on one of the gear once warmed up sciconf Generation Two 1 03-18-2019 07:15 PM
HELP! need advice and tip. bay06 Your Integra 3 11-27-2018 12:07 PM
Reverse light switch Heath Mclamb Generation Three 2 08-24-2018 02:41 PM
replaced clutch but wont go into gear IsaiPerez63 Generation Three 1 03-01-2018 07:25 PM
