95' integra LS check engine light Help - Team Integra Forums - Team Integra
post #1 of 2 (permalink) Old 03-15-2019, 02:52 AM Thread Starter
Bree33's Avatar
(i couldn't find a topic on check engine lights any where I'm sorry if there is one point me in the right direction if there is please!)
My car is lowered and I went to get gas and as I left gas station I was doing 3mph at most and I was going at an angle ( prior to this I have bad mounts) and it sounded like my engine smacked the ground but theres no leaks no scrapes and the mounts are like it were before. I took it to a Japanese car specialist and he reset the battery and it came back on he said it may be a shortage but he doesn't know where. I guess what I'm really asking for is what am I looking for as a shortage and where should I look for the shortage? If you can please point me in the right direction I will appreciate it!
Bree33 is offline
post #2 of 2 (permalink) Old 03-15-2019, 02:38 PM
Good question. Perform the following test on your own:
1. Take a paper clip, or if you don't have it take a piece of a spare wire approximately 1.5" long. Any small diameter wire would work. Strip both ends of this wire (remove insulation).
2. Bend the wire or the paper clip in half (equal length)
3. Get under the dashboard on the passenger side and look for a light blue (2-pin) electrical connector on the right side under the glovebox department, next to the kick panel (if I remember it correctly). Should look like this:
4. Insert each end of your wire into the connector, one wire in each hole:
5. Now get in the driver seat and turn the ignition to ON but do not start the car.
6. Begin counting the check engine light blinks. The light shall first blink slow, then fast. Count how many times it blinked slowly and how many times it blinks fast. Each slow blink represents number 10, where as each fast blink represents number 1. So for example if you have 3 consecutive slow blinks followed-by 6 consecutive fast blinks the number is 36. Then there will be a pause in blinking, followed-by another set of blinks. If there are multiple check engine light triggers, than the second set of blinks would allow you to identify code #2 and so on. If the seconds set of blinks becomes repetative, then there are no additional codes to read. You can have many codes or only one. Once you read all the codes, report back and we will try to provide further assistance.
Similar Threads
SW PA: Integra Parts Sale! danteisme For Sale Section - Parts 11 03-29-2019 10:52 AM
Engine died at stop light and won't turn on anymore. Gungis The TI Pit Area 2 01-24-2019 06:46 PM
Help integra won’t go over 4,000 rpm 94 integra LS 1.8 Non vertex STZ1994integraLS1.8 Generation Three 2 10-02-2018 05:50 AM
Integra aficionados assemble! 1992 Integra will not start Daniel Ortega Generation Two 2 09-24-2018 10:28 PM
- IMPORTEKNIKAICR: 10? Make That 18 Years of Integra! - IMPORTEKNIKAICR Your Integra 29 02-27-2018 10:26 AM
