My First Standard and First Teg!! 97 LS - Team Integra Forums - Team Integra
 4Likes
post #1 of 42 (permalink) Old 08-30-2015, 11:32 PM Thread Starter
Hey Guys! About a month ago I bought my 97 LS Integra! Paid $1200 and it ran well enough. I've already done some work on it and I'll start posting things here! I'm 17 and wanted a car I could learn to work on and a car that's a blast to drive. I think that's what I've found!
biker_seth is offline
post #2 of 42 (permalink) Old 08-31-2015, 10:12 AM
Congrats. My first car I ever started working on was an Integra. Learned to change a headgasket before I learned to change brake pads
Bless this simple engine layout, and easy-to-reach components.
Bretherman is offline
post #3 of 42 (permalink) Old 08-31-2015, 11:11 AM
Congratulations man just got mine a few weeks ago im 18 and i paid 1000 cant wait to se yours
Cameronn is offline
post #4 of 42 (permalink) Old 08-31-2015, 07:25 PM Thread Starter
Pictures!
Here's some pictures of my car now, I've already done a couple things so I wish I would've started documenting sooner but eh...
post #5 of 42 (permalink) Old 08-31-2015, 07:42 PM
Where are the pictures? Cant see them bro
Cameronn is offline
post #6 of 42 (permalink) Old 08-31-2015, 08:49 PM Thread Starter
Here we go
ID:	53514   Click image for larger version
ID:	53522   Click image for larger version
ID:	53530   Click image for larger version
ID:	53538   Click image for larger version
ID:	53554   Click image for larger version
ID:	53562   Click image for larger version
ID:	53570   Click image for larger version
ID:	53578   Click image for larger version
post #7 of 42 (permalink) Old 09-01-2015, 09:26 AM
4drNepS's Avatar
nice man congrats
4drNepS is offline
post #8 of 42 (permalink) Old 09-01-2015, 11:26 AM
Looking really good man
Cameronn is offline
post #9 of 42 (permalink) Old 09-01-2015, 08:50 PM Thread Starter
oil change(cover my bases)
CV axle replacement both sides: one side failed the day after I bought the car, they were both going out but my rough shifting learning was the last straw im guessing.
IACV diagnostic(it's bad)
adjusted idle to compensate for disconnected IACV
Ordered IACV
repainted wiper blades
corrected tire pressure(uneven&low)
Removed driver side dash
Discovered Theft prevention system
Replaced Main Relayfuel pump wasn't firing up: problem solved)
checked continuity on battery and starter(click when attempting to start car had to try multiple times to start. Got worse and wouldn't start.
Checked Battery
Cleaned Battery terminal & connections
purchased Stater parts(doing rebuild tomorrow, copper contacts mostly
Adjusted e brake tension
Installed new IACV (not idling correctly)
Rebuilt starter, works perfectly.
That's it so far
Jeffaome likes this.
post #10 of 42 (permalink) Old 09-01-2015, 09:39 PM
Make sure all your grounds in the engine bay are good.
I had a starting problem a while back, and it was a crappy ground wire.
post #11 of 42 (permalink) Old 09-02-2015, 12:13 AM Thread Starter
Will do just in case!!
post #12 of 42 (permalink) Old 09-03-2015, 12:01 AM Thread Starter
Fixed Starter!!
This is me removing the starter, replacing the contacts and cleaning the inside. I put it back in and now the car starts again!!! Man I've missed driving it this past week! But MAN was that lower bolt a pain to remove.
special thanks to
@BSQ5 (https://www.team-integra.net/forum/19...than-20-a.html)
and
@fast95se (G3 Starter Rebuild - Team Integra Forums - Team Integra)
for the info!
post #13 of 42 (permalink) Old 09-03-2015, 12:06 AM Thread Starter
freakin picturez
Dang pictures never work the first try -_-
ID:	53946   Click image for larger version
ID:	53954   Click image for larger version
ID:	53962   Click image for larger version
ID:	53970   Click image for larger version
ID:	53986   Click image for larger version
ID:	53994   Click image for larger version
ID:	54002   Click image for larger version
ID:	54010   Click image for larger version
knavekid and Bretherman like this.
post #14 of 42 (permalink) Old 09-03-2015, 01:46 PM Thread Starter
rotors
What do you guys think? Do I need new rear rotors? Both are like this.
