GODSEND DC2 Log .... Life after death the rebirth of an R - Page 23 - Team Integra Forums - Team Integra
 224Likes
post #309 of 336 (permalink) Old 06-07-2018, 02:11 AM Thread Starter
Send a message via AIM to JDMJNKY Send a message via Yahoo to JDMJNKY
Tonights post is simple and sweet. Finding, organizing, and uploading the engine images have become a task of its own.
- LMAs ( Lightened, polished, positionally balanced )
Gross Weight Vs Gross Weight Reduction
safe to say "net weight" vs. "net weight"-reduction?
* Ninja Edit. I may have left the nuts and screws in the OEM LMAs. I'll have to weigh those separately and re-calculate. Upset I didn't take a picture of the items facing the same way. Doesn't seem like something I'd do, but it happened. I do not wish to share mis-information, nor do I wish to spread "inflated" data.
Thanks
Joel.
1213 AFFILIATION - JDMKIDS | CALI LOVE | AS1 FAMILIA
1213 AFFINITY - Integra Log | NITE GRIND TRANSMISSIONS | GRIPSET | NASTIE GARAGE | CALI LOVE CLOTH. |
JDMJNKY is offline
post #310 of 336 (permalink) Old 06-08-2018, 01:35 PM Thread Starter
Next, I focused on the cylinder head, where I'd use my skill or lack thereof to port it, polish the chambers and exhaust housing.
The stages of port work. For the Exh side, I only remove casting flaws and bend the bowls. For the intake side, I open that up and port match per gasket. The "swirl scars" were left purposely. This will be the first engine out of two that I built that I've tried the polished exhaust and combustion chamber. The other head is much smoother.
All ready to drop off at the machine shop.
JDMJNKY is offline
post #311 of 336 (permalink) Old 06-09-2018, 11:47 PM
Silvia's Avatar
Been awhile since I last visited your page. New project is looking good!!!!! Someday I will take the time to strip my car down and do a restore on all the parts also.
JDMJNKY likes this.
Silvia is online now
post #312 of 336 (permalink) Old 06-14-2018, 03:02 AM Thread Starter
Thanks Silvia, trying to take my time and give it a solid go. I hope the forums are stringer than ever and I get to stop in and check on you!
Let the bottom end begin…. I’ll elaborate if that’s ok with everyone. I hate to be long winded sometimes but it may be the only way things take shape. My goal for this engine as stated before is primarily efficiency and longevity. I bought the block and cylinder head separately not knowing hoe they once lived their lives. I do know the cylinder head was a virgin.
The block, I knew nothing about it, except it was a b18c5 missing pcs. The only pcs I never logged, or can’t seem to find image of are the crank and rods. I did know that I wanted a engine with a slight bump in factory power, a race motor wasn’t necessary. With all the machine work, flat valves, and USDM CR pistons; I’d land right where I wanted to be all said and done w/ a JDM B18C ratio. The cams being a hare more aggressive than a CTR, the intake manifold out flowing the JDM ITR, and the header being the best complimentary to mid range ( like the JDM ITR header ) would mentally make this my perfect blend of a stock motor w/ bolt ons.
The classic, tried and true Nippon piston. I later ditched the pistons rings in favor of the hi-po version rings.
rods & pistons mated, this is after the rotation assembly balancing
back peddling a bit, Engine layout. This is the only image I have that has the water pump, oil pump, etc before assembly. I’m sure everyone know the concept of this image, LOL.
edited version
Block Assembly
Let's kick this off w/ the one and only..... bare naked bruiser
Hope the plasti-gauge is visible
It is/was, very difficult to take an image of this step haha - holding the camera with one hand, trying to press the snap button and keeping this gauge "ruler" on point w/ the other. Brain tease for sure.
Now here's my doubtful nag in the back of my mind until this day...Should I had ceramic coated the combustions chambers as well, instead of slaving on polishing them? I'll never know (unless I have to rebuild this setup, Gods pray life, I never have too.)
No need to waste paper, I'll just write it on the block.
Missing Files - Ecstatic I Found these; no special order.
Same Edelbrock 4730 cams, just redecorated.
9TechNine9 and blandsarcasm like this.
JDMJNKY is offline
post #313 of 336 (permalink) Old 06-14-2018, 04:31 PM
blandsarcasm's Avatar
This is awesome! Iím hyped to see all the progress thatís been made on this car
Sent from my iPhone using Tapatalk
JDMJNKY likes this.
blandsarcasm is offline
post #314 of 336 (permalink) Old 06-14-2018, 07:11 PM
9TechNine9's Avatar
Man, the attention to detail..
JDMJNKY likes this.
9TechNine9 is offline
post #315 of 336 (permalink) Old 06-14-2018, 09:29 PM Thread Starter
Thank you gentlemen.
JDMJNKY is offline
post #316 of 336 (permalink) Old 06-15-2018, 02:13 AM Thread Starter
PART 2 of the Engine Assembly
JDMJNKY is offline
post #317 of 336 (permalink) Old 06-17-2018, 03:42 AM Thread Starter
ITR Bits....when the meticulous me is unleashed.
9TechNine9 likes this.
JDMJNKY is offline
post #318 of 336 (permalink) Old 06-19-2018, 12:42 AM Thread Starter
Induction Planning
Knowing the specs of my build to be, I wanted the best manifold I could purchase for the coin. Thanks to what's left out there I concluded the performer X would be the one. It was just a matter of finding one. After I purchased mine, it seems they surfaced more frequently. Just happy I was able to locate one in good condition.
Port Matched to Gasket.
IDK why, but I found this cool. An imperfection in the casting.
Exhaust Improvements
As mentioned before, this engine was never destined for massive power, just a power up. I didn't mind that a real toda header wasn't implemented because I'm not after the cool points. I just want what works. I do know and fully understand the weight of my choice. There's a unfortunate gary area for me with replica parts.
Lesson? Quality suffers, when saving pennies. Good thing my port hand was way strong this day!
Final Finish
Engine Assembly Continued
The Joy of building/assembling something with your own two hands. Not everyone can purchase brand new parts, so I hoped to build this engine and inspire those. I see tons of cars loaded with mods, just to see their mods list two iPhone note pages long. Some of the most hideous mods you can put on a car. The point is, tact. A little paint goes a long way, a little cleaning makes old look new, a little planning saves waisted time and money on senseless mods.
There was so much prep to give it that fresh look without buying new bolts or paying to have them re-zinc'd. It was the proper "patina."
JDMJNKY is offline
post #319 of 336 (permalink) Old 06-19-2018, 05:04 PM
Nice dude
FreshGSR is offline
post #320 of 336 (permalink) Old 06-21-2018, 11:46 PM Thread Starter
Thanks Man!
JDMJNKY is offline
post #321 of 336 (permalink) Old 06-22-2018, 08:24 AM
danteisme's Avatar
Originally Posted by JDMJNKY View Post
Is this what they call an exploded view?
lol seriously though, that motor looks beautiful, excellent work and attention to detail for sure.
Bloggity Blog
danteisme is offline
post #322 of 336 (permalink) Old 06-28-2018, 02:55 AM Thread Starter
I'd say so.All the insides outside? I'm sure we could all agree.
Thanks man, it's the cleanest engine/swap I've had to date LOL.
Long days, Low pay, Short stay-cation = brief hiatus.
Today's update in short, I lost footage moving from phone to phone and my documentation is suffering a bit. but I pieced together a J4D LSD spec gearbox. Gave it a overhaul and fitted it with a USDM LSD. I could have spent less with certain aftermarket bits but this was sort of a purist decision.
Unfortunately, the cleaning procedure does harm the labels, stamps, and vin tag at this level but onward and upward to some DSLR shots.
P.S. This is not new hardware either, I found the best looking hardware I could over the past 2yrs and I cleaned them up. I shouldn't be prideful in the matter but I love the zinc appearance from factory. Hope you guys enjoy the visuals.
IntegraCF21 and blandsarcasm like this.
JDMJNKY is offline
