danteisme's 1996 DB8-Found and Rebuild Thread - Page 24 - Team Integra Forums - Team Integra
 225Likes
post #323 of 715 (permalink) Old 01-21-2016, 10:45 AM
Frany's Avatar
Part No. 16919-ST7-930
Band, Fuel Strainer
Frany is offline
post #324 of 715 (permalink) Old 01-21-2016, 10:49 AM Thread Starter
danteisme's Avatar
ooooh, that piece that broke off in the tube is actually part of the band itself?
Bloggity Blog
danteisme is offline
post #325 of 715 (permalink) Old 01-21-2016, 10:51 AM
Frany's Avatar
Yes, I broke mine as well and just removed it completely.
Frany is offline
post #326 of 715 (permalink) Old 01-21-2016, 11:20 AM Thread Starter
danteisme's Avatar
i cant recall, does that other end of the line plug into anything...is it part of the canister?
post #327 of 715 (permalink) Old 01-31-2016, 09:17 PM Thread Starter
danteisme's Avatar
alright... the theme for this weekend's work was RUST. i felt like i spent 90% of my time breaking bolts and having to drill them out of the car. so before i finish up the brake line installation, i need to order all new brake line clips. i removed the old rear brake hoses and there is a mounting clip on these too. i cant tell which they are in the parts diagram though.... here is the diagram:
and here is the rusted up parts (ignore the bent one, i bent it trying to undo that 12mm bolt)
i'm 90% sure these are not on my new brake hoses, but i ran out of daylight to track down what box o parts they are in and confirm. is this piece on that acura break down above?
i'll upload some more pics of the little work that actually looks like i did something
post #328 of 715 (permalink) Old 02-01-2016, 09:07 AM
Dustin96LS's Avatar
Is it inside sub-assembly "1"? Kind of looks like it but I can't tell for sure. It might be in the breakdown of the caliper itself possibly? Assuming this is the piece of line right before it runs to the caliper.
Dustin96LS is offline
post #329 of 715 (permalink) Old 02-01-2016, 09:15 AM Thread Starter
danteisme's Avatar
oops, these are for the rear. so it would be under "3" or "4", but i dont see anything that quite looks like them. i'll dig up the caliper breakdown and check there. or if i get home in time tonight i'll dig for my new brake hoses
edit: think i found it. i started thikning about where this piece connects to, and to the best of my memory it connects to the rear trailing arm.
number 3 and 4 in this image...pretty sure.
post #330 of 715 (permalink) Old 02-01-2016, 11:19 AM Thread Starter
danteisme's Avatar
so as promised here are my mediocre (at best) updates. i have all of coolant lines etc.. to replace all of those and all of the pieces i need to install the ITR oil cooler. i'm placing an order today to acura...again...ugh $$$$...to order all new brake line clips. once i get those pieces on hand, i can finish installing the fuel/brake lines and get the subframe back in the car. after that, its on like donkey kong with the motor work.
so i'm hoping for this weekend coming up that i can finish re-assembling the subframe and rack and get that ready to go, replace the plethora of coolant lines on this motor, and install the ITR oil cooler to the back of the block. that is the game plan as of right now.
as for work i did this weekend, not much beside breaking bolts and drilling them out. i'm still nursing my lower back to get back to 100% so my work this weekend was mainly cosmetic. i prepped my valve cover and painted it (no pics yet), and i prepped the engine bay to make it a little more respectable lol.
this is using that ford green color by the way.
here is some before pics to refresh memory:
after my rattle can job:
MorningZ likes this.
post #331 of 715 (permalink) Old 02-03-2016, 01:24 PM Thread Starter
danteisme's Avatar
BAH! so i checked on my valve cover last night and the paint didnt take very well. i'm thinking one of two things happened. 1. it got below the temp threshold for this stuff to cure or 2. i put it on too thick.
looks like i'll be stripping this back off and starting over again.
this was with wrinkle type aerosol paint.
post #332 of 715 (permalink) Old 02-03-2016, 01:55 PM
Yikes, yeah, if PA got into freezing temps that would definitely muck things up..
post #333 of 715 (permalink) Old 02-03-2016, 01:55 PM
Did you cure it in the oven? I did mine and regretted it. It started flaking off in about a year. Next time I'm either leaving it sanded for the "brushed aluminum" look or Saving a Lil more to get it powder coated.
dhabell is offline
post #334 of 715 (permalink) Old 02-03-2016, 02:10 PM Thread Starter
danteisme's Avatar
yup, i believe that is what happened. it was in the mid 60's all day and i bet it dropped below 50 in the evening and then the next day it dropped all day.
shame on me for not looking at my weather app lol
post #335 of 715 (permalink) Old 02-08-2016, 08:23 AM Thread Starter
danteisme's Avatar
still no brake line parts from acura...and to add onto that i received a refund for 2 parts i ordered. it turns out those brake hose mounts to the rear trailing arm are discontinued. great! awesome! grand!
oh well. even if the brake line parts show up this week, unless the forecast changes i dont see myself wrenching next weekend. the high is projected to be 12 or 13 and the low -2. i dont think my kero heaters will be able to do much in that kind of cold. we'll see.
post #336 of 715 (permalink) Old 02-08-2016, 02:53 PM
jae_rex's Avatar
That paint job on the engine bay is looking good. Keep up the good work.
danteisme likes this.
01 AP1/ 87 VW MKII / 97 BMW 328Ti /96 DC2 /02 EP3 Build thread
jae_rex is offline
