Kamikaze's 2L Poorman's R Log. **MorningZ I Want My Cake** - Page 47 - Team Integra Forums - Team Integra
 148Likes
post #645 of 681 (permalink) Old 07-17-2015, 07:20 PM Thread Starter
Kamikaze's Avatar
@Jeffaome the impact of the balljoint crumpled it and getting it on the tow truck completely fubar'd it. @dpaton yes it is
My Running Log!
Built Not Bought
: The anti-chequebook approach to the restoration and modification of old cars. Budget, DIY home-grown fabrication and dedication as opposed to ready-made parts. In the shed, not off the shelf.
Kamikaze is offline
post #646 of 681 (permalink) Old 07-17-2015, 08:17 PM Thread Starter
Kamikaze's Avatar
Her resting place. Mutt pulled it off and tried to straighten it up no luck...
Also got a problem now where it sounds like a Subaru under load. It's very intermittent started this morning on cold start then after work about way home. Then went away and started again the latter part of my drive home. Pulled the wires, idles down on each one. Then it seems to go away
Kamikaze is offline
post #647 of 681 (permalink) Old 07-17-2015, 08:58 PM
Jeffaome's Avatar
Fill it with good gas, change the plugs and try Mutt's distributor
Jeffaome is offline
post #648 of 681 (permalink) Old 07-18-2015, 12:45 PM Thread Starter
Kamikaze's Avatar
Issue I believe us from iacv, code are 7,14, 21 now. So tps, iacv, and vtec solenoid. Probably on lunch will take iacv out and attempt to clean it is biggest issue runs fine but feels like running on 3 cylinders sounds like a Subaru
Kamikaze is offline
post #649 of 681 (permalink) Old 07-19-2015, 04:12 PM Thread Starter
Kamikaze's Avatar
Well woke up this morning noticed a grind in the top of 3rd and I had a surprise quart of Honda mtf in the back put it in still grinds... Also took off the iacv, cleaned it let it sit in the sun to air dry seems like it got a ton worse at first disconnected the battery and pulled the backup fuse seems like the idle is better haven't pulled codes again. I have a chart now with a checklist of things to get done and I plan by December'ish to be done with a majority of it.
Kamikaze is offline
post #650 of 681 (permalink) Old 07-19-2015, 04:33 PM
maybe try some torco MTF? a friend of mine was experiencing a third gear grind when driving hard on his b16 transmission and torco mtf reduced his grind
aw614 is offline
post #651 of 681 (permalink) Old 07-19-2015, 04:42 PM Thread Starter
Kamikaze's Avatar
Noted @aw614
Kamikaze is offline
post #652 of 681 (permalink) Old 07-22-2015, 12:12 PM Thread Starter
Kamikaze's Avatar
Think my injectors wiring are fouled up
Kamikaze is offline
post #653 of 681 (permalink) Old 07-24-2015, 11:07 AM
dpaton's Avatar
Fouled up as in intermittent connections, or fouled up as in crossed up?
dpaton is offline
post #654 of 681 (permalink) Old 07-24-2015, 12:58 PM Thread Starter
Kamikaze's Avatar
Intermittent, all I did was snug the wires up I suppose and it's good now it seems.
JDMJNKY and dpaton like this.
Kamikaze is offline
post #655 of 681 (permalink) Old 07-26-2015, 10:34 AM
mutt8588's Avatar
So, in the vzw parking lot at work, we FINALLY got solid readings off the tps. I put in a new pigtail last week. Now that we had signal we tried adjusting it, but the tb had the tps in the wrong position and wouldn't go past 3.8 wot. Swapped back to a stock tb and finally got good readings. We got the top set to 4.8 but with that set right the closed it .8. When we were at .5 closed it was in the high 3.x wot. So not sure why we can't get it dialed in. But a step forward has occurred!!
JDM from the womb to the tomb
Mutt's Log
mutt8588 is offline
post #656 of 681 (permalink) Old 07-26-2015, 06:37 PM Thread Starter
Kamikaze's Avatar
Well after monkeying with the idle some more, I looked at a guide that involved pulling the iacv setting it and removing the battery. So I'll take it out a little bit later.... NOW!!!!! ONLY 1 MORE CEL. for the vtec solenoid. Going to try to tackle that tomorrow. OMG I'm more than happy, big huge shoutout goes to mutt.
hungry718, mutt8588 and aw614 like this.
Kamikaze is offline
post #657 of 681 (permalink) Old 07-27-2015, 03:44 PM Thread Starter
Kamikaze's Avatar
Iacv is going to have to be replaced completely. Started happening again where it starts to feel like it's running on 3 cylinders again. Going to replace the thermostat this weekend and hopefully mutt can find his spare and I can use it to replace mine.
Kamikaze is offline
post #658 of 681 (permalink) Old 07-27-2015, 04:29 PM
Jeffaome's Avatar
Does it only misfire a idle? Where are you getting IACV from a misfire? Look at the ignition system first, then fuel.
Jeffaome is offline
