ASR 32mm Hollow Rear Sway Bar - Team Integra Forums - Team Integra
post #1 of 5 (permalink) Old 01-30-2019, 12:39 AM Thread Starter
Hey guys,
Does anyone have experience with the ASR 32mm Hollow Sway Bar? I'm contemplating between this and the 25mm hollow bar. The car will be used for AutoX and track days, while remaining a DD.
Educated thoughts are also welcome.
Thanks,
Cameron
CgDeans is offline
post #2 of 5 (permalink) Old 01-31-2019, 12:00 PM
dpaton's Avatar
What do you have currently? What are your goals? What's your experience?
dpaton is offline
post #3 of 5 (permalink) Old 03-09-2019, 07:00 AM
alittlewantto's Avatar
You do realize running the bigger sway bar requires also running a subframe brace right? I'm running the asr subframe brace and 24mm solid sway bar. I don't run auto x but I do dd.
alittlewantto is offline
post #4 of 5 (permalink) Old 03-09-2019, 09:49 AM
Absolute_Yeti's Avatar
32 is a little excessive if it's also your DD and assuming no other supporting mods. basically it's a chain of weakest link components. if the swaybar and end links aren't it, it'll be another component that will give (bolted on or welded on.)
i stole this chart of oem sizes below, i wouldn't go beyond 3mm larger without extra bracing in various know places.
Depends on the years 94-01 Integra:
RS, LS, GS, SE Coupe - Front sway bar
22mm (94-99)
24mm (00-01)
Rear Sway bar - 13 mm
94-01 RS, LS, GS, SE Sedan
22mm (94-99)
24mm (00-01)
Rear Sway bar - 14mm
B18b1
Absolute_Yeti is offline
post #5 of 5 (permalink) Old 03-12-2019, 01:30 PM
The 32mm comes in different wall thicknesses so you also need to determine which thickness you want to run, I can't recall which one is recommended for autox. It also might have some exhaust clearance issues.
Personally, unless you are already experienced and need more rear bar, I'd run the ITR 22mm/23mm, ASR 24mm or ASR 25mm hollow bar.
Currently happy with my 25mm hollow bar, and previously I ran the ITR 22mm.
aw614 is offline
