ABS Delete on a ‘96 integra 3rd gen. base model - Team Integra Forums - Team Integra
post #1 of 3 (permalink) Old 11-07-2018, 07:02 PM Thread Starter
Hi I own a 1996 3rd gen base model integra and I was hoping someone could help me figure out which parts I need to remove the ABS system from the car. From what I’ve researched I need a 40/40 proportioning valve with the lines, and a replacement master cylinder. So can someone clarify where I can get these parts from? I think I can get all the parts from a 3rd gen integra rs or a 92-95 civic with no ABS but could someone help explain for me? I’m kinda lost on what to do.
Kieran Shepherd is offline
post #2 of 3 (permalink) Old 11-12-2018, 07:09 PM
look between the rs and what you have now, believe you can leave the rear main lines alone(i might be wrong because my rear lines were rusted and leaking so i replaced), but everything forward needs to be changed over, i decided to delete abs out of my current integra due to previous owner cutting all the lines and my donor car was non abs.
will need to change the master, lines from master to prop valve, the prop valve, lines from valve to front spindles, and maybe the rear lines, but i could be wrong.
also will need to remove or unplug the ABS computer, or your light will be on the dash.
'93 RS - Spun Rod
'91 LS - Folded Rear Subframe
'95 RS jdm gsr swap on b16 trans - Tboned
'95 LS full JDM GS-R Swap - DD
Mikimaru is offline
post #3 of 3 (permalink) Old 11-13-2018, 05:35 AM
You better check with your state law about removing the ABS system.
About time I can now apply for Historic Tags for my GS/VTEC Automatic and no more SMOG
In other news: New edition to the family born on August 21, 2018 @ 3:10am
phatintegra is offline
