is a new ABS sensor needed for type r suspension swap? - Team Integra Forums - Team Integra
post #1 of 5 (permalink) Old 09-06-2018, 04:18 PM Thread Starter
I was looking into getting the inegra type R shocks and springs for my 1996 GSR. I know that i will need to get the rear lower control arms for sure.
I found this article that states that the type r abs sensor lines are needed as well.
Build Your Own Type R Suspension
None of the other guides i have seen have mentioned the abs lines, is it possible to use the stock GSR abs lines or do i need to get the type r ones?
Thanks!
Wulfspade is offline
post #2 of 5 (permalink) Old 09-06-2018, 06:10 PM
I did not read the article that your referred to. In my opinion, you should not be required to replace the existing GSR ABS sensor with a Type R ABS sensor when replacing shocks/springs and control arms.
post #3 of 5 (permalink) Old 09-06-2018, 07:45 PM Thread Starter
Their reasoning was that the mounting limits
Points on the type r control arms was different for the sensor.
Is it something you can just zip type on?
post #4 of 5 (permalink) Old 09-06-2018, 11:20 PM
I used zip ties after upgrading suspension on my Integra.
post #5 of 5 (permalink) Old 09-07-2018, 04:00 PM
I also used zip ties to hold the abs sensors on. I have not had any problems and I've been running the LCAs since 2014.
I
aw614 is offline
