Passenger Wheel camber is really off?! - Team Integra Forums - Team Integra
  • 1 Post By jjkz24
post #1 of 8 (permalink) Old 10-05-2017, 02:52 PM Thread Starter
I had an accident a little while back and it forced me to replace the brake line caliper, fender, and upper control arm. I took the car to get an alignment and new tires and have been driving it with the camber on the passenger side at about -3 and the drivers close to 0. I decided to replace the lower control arm a week ago amd everything went smooth but, by eyeing it, the camber looks only a little bit better than what it was. The car also pulls to the left pretty quickly.
nomunic is offline
post #2 of 8 (permalink) Old 10-05-2017, 04:52 PM
The previous alignment sounds like it was performed on bent/defective parts. Now that you've replaced the, you're going to want another alignment.
post #3 of 8 (permalink) Old 10-05-2017, 06:23 PM Thread Starter
But our vehicles don't have adjustible camber so wouldn't there be something else going on?
nomunic is offline
post #4 of 8 (permalink) Old 10-09-2017, 07:59 AM
Why in the world do you think that our cars do not have adjustable camber?
post #5 of 8 (permalink) Old 10-10-2017, 12:40 AM Thread Starter
When I was given the data sheet it stated that camber didnt change but the caster and toe did slightly. The guy told me he couldn't do anything without a adjustible kit on the car. Is this true?
nomunic is offline
post #6 of 8 (permalink) Old 10-10-2017, 06:44 AM
Yes, this is true. The camber adjustment is more than likely maxed out, hence the suggestion of needing a camber kit. But that doesn't mean that it can't be adjusted at all, as you mentioned above. Our car's camber can indeed be adjusted from the factory, with or without a camber kit.
nomunic likes this.
post #7 of 8 (permalink) Old 10-10-2017, 07:43 PM Thread Starter
So I'll go ahead and get an alignment, if that doesn't work what do you think should be my next step? (By the way there is no frame damage).
nomunic is offline
post #8 of 8 (permalink) Old 10-10-2017, 10:28 PM
I would still invest in a camber kit. You may not have enough adjustment to get your camber within spec.
