Tighten suspension - Team Integra Forums - Team Integra
post #1 of 11 (permalink) Old 01-29-2016, 11:49 PM Thread Starter
Tighten suspension
When I bought the 99 LS 2 door, it came with these lowering struts and rear and front tie bars in it. The handling felt great but it was way too low, I was scraping everywhere.
I had the stock springs and struts placed back in to raise the car and also pulled out the rear tie bar for cargo space. But now the handling has gone down. I can feel the car rock/sway left and right a good bit when driving.
How do I tighten up this suspension with what I've got, without lowering the car again?
ID:	60441   Click image for larger version
stvpourciau is offline
post #2 of 11 (permalink) Old 01-30-2016, 12:03 AM
Bushings, sway bars, tires, alignment, weight reduction.
NewtGomez is offline
post #3 of 11 (permalink) Old 01-30-2016, 11:29 AM Thread Starter
What do you mean by bushings? Are there "upgrade" bushings? Or that they may be worn? I've anything on my car was worn my mechanic would've replaced it.
I've got new tires/light rims, good alignment, so my only option now is sway bar? Do you think that tie bar has any effect?
post #4 of 11 (permalink) Old 01-30-2016, 11:57 AM
New bushings as in poly bushings for example energy suspension sells a master kit of polyurethane bushings that stiffen your car up. The tie bar you are talking about is usually called a strut bar and I believe it's mostly a placebo effect. You won't gain anything noticeable really. Thicker sway bars will make a drastic difference in preventing body roll. The best thing I ever did to my teg was an ITR rear sway bar. If you upgrade your rear sway bar, you should definitely consider buying a subframe brace so you don't tear out your subframe.
post #5 of 11 (permalink) Old 01-30-2016, 12:14 PM Thread Starter
Thank you for your reply. Don't they sell sway bars now that dont tear out?
post #6 of 11 (permalink) Old 01-30-2016, 01:47 PM
drmix's Avatar
Thats what the subframe brace is for. It will distribute the force of the sway bar over a large surface rather than a small surface which will prevent tear out.
drmix is offline
post #7 of 11 (permalink) Old 02-02-2016, 05:20 PM
nick-flanders's Avatar
Feedback Score: 22 reviews
Factory springs are going to feel "sloppy" compared to aftermarket springs. Are your shocks worn out?
I would never accept that from my paint guy..
nick-flanders is offline
post #8 of 11 (permalink) Old 02-02-2016, 07:29 PM Thread Starter
I wouldn't know. My mechanic didn't see any obvious damage so we threw them in.
post #9 of 11 (permalink) Old 03-05-2016, 07:14 AM Thread Starter
Yes, they're completely shot. I'm going to throw the tokikos back in and relower it, there's already an upgraded sway bar. Someone put time into the suspension and I destroyed it
post #10 of 11 (permalink) Old 03-05-2016, 04:48 PM
You could also go for the type r springs on the tokiko struts for some lowering and better handling
dudeskee1325 is offline
post #11 of 11 (permalink) Old 03-05-2016, 05:01 PM
New bushings (not necessarily aftermarket ones) will definitely improve feel if the current ones are worn out. Peek down in the back and check them. They are kind of a B to replace, so I'm not sure it's something a mechanic will do without letting you know.
A sway bar will definitely improve feel.
If you have the funds, you can go for coilovers. Normally they let you adjust the stiffness and height, and some will let you do it without messing with smooth suspension travel.
Heck, I think Tein even makes a little control unit that lets you adjust stiffness (not ride height unfortunately) from inside the car instead of having to get out and adjust them yourself. Not that it takes a long time anyways, but you just run little motors to the tops of the shocks and I think that's awesome.
A turbo build log should be called a turbo lag.
Get it? Heh heh heh...
...I'll show myself out.
Bretherman is offline
