dc2 cluster issue - Team Integra Forums - Team Integra
post #1 of 6 (permalink) Old 05-02-2019, 12:57 AM Thread Starter
vteg818's Avatar
dc2 cluster issue
hello, ive been having an issue with my integra where nothing from my cluster has been working, the only things that light up is the battery light and high beam and turn signals, ive checked fuses theyre all good. i have a feeling something is loose cuz when i drive over a bump the cluster does start to work for a bit but usually stops working. what can i check for loose grounds or connections? thanks
vteg818 is offline
post #2 of 6 (permalink) Old 05-02-2019, 12:51 PM
Pull it out and check your connections. Plenty of youtube videos showing how to remove the cluster.
Being married is like being on a diet...you're hungry and all you can do is look at the menu.
silverctr98 is offline
post #3 of 6 (permalink) Old 05-02-2019, 01:23 PM
Absolute_Yeti's Avatar
check the connections and check the harness for visible wear or tampering. I've see some interesting splice jobs on clusters before to get signals for extra gauges and such.
B18b1
Absolute_Yeti is online now
post #4 of 6 (permalink) Old 05-02-2019, 02:35 PM Thread Starter
vteg818's Avatar
Yea ive swapped the cluster with my friends cluster as well to see if it made a difference but same result, and connections are good no splice or nothing
vteg818 is offline
post #5 of 6 (permalink) Old 05-02-2019, 04:02 PM
In that case the next steps would be check for blown fuses and maybe find another ECU to test with.
this is a good resource for identifying the ecu.
https://www.hondata.com/tech-ecu-identification
post #6 of 6 (permalink) Old 05-02-2019, 07:43 PM Thread Starter
vteg818's Avatar
Yea i have another ECU aswell since im tuned on p72obd1 but i have my original p72 obd2 still the same and fuses are good, thanks tho yea its wierd
vteg818 is offline
Similar Threads
Rear Defroster Issue Woofer Pressure Generation Three 0 12-08-2018 11:04 AM
Instrument cluster spots Gabriel Fong Detailing 0 07-04-2018 03:28 PM
96 gsr cluster not working but fuel gauge works 96gsrheadachecar Intl Forum 0 04-22-2018 04:45 PM
Power limit issue on 2000 GS nicoleen7 Performance 1 04-06-2018 10:43 AM
