00 LS Key Fob Not Responding? - Team Integra Forums - Team Integra
post #1 of 3 (permalink) Old 03-29-2019, 03:33 PM Thread Starter
Exclamation 00 LS Key Fob Not Responding?
As title states I have a weird problem with my Integra. The Key FOB has a battery that works, it lights up when buttons are pressed but the car doesn't seem to respond to the FOB. It starts with the key, doors will lock manually, but the alarm does not set and the doors do not lock via key fob. Is it possible the receiver in the dash has gone bad or disconnected? I'm not entirely sure how the alarm/lock feature works with key FOBs.
- Doors do not lock via key fob
- Alarm does not set
- Key FOB battery is good
Thanks for the help
Dylan James is offline
post #2 of 3 (permalink) Old 04-01-2019, 06:23 PM
You need to determine what alarm is installed in the car. Then google how to reset the alarm. It should be an easy fix. Something like, open the drivers door, then press 1,2,1,2 on a remote. Just an example. You must have accidently pressed a combination that put it in a limp mode.
Built_not_bought is online now
post #3 of 3 (permalink) Old 04-12-2019, 11:38 AM Thread Starter
Thank you, I managed to reset it yesterday but then after 10 mins it disconnected again, might have a dealer look at it. I'm not sure.
