99 gsr sputtering when in vtec?????? - Team Integra Forums - Team Integra
  • 1 Post By 1FSTGSR
post #1 of 8 (permalink) Old 08-30-2002, 02:13 AM Thread Starter
well it just started about two days ago when i try to go into vtec it doesnt sound like it is engaging in the first stage then i can hear it go into the second stage and it sputters but only when i go past 6 grand. anybody experience this? anybody know what may be causing it?
gsr9901 is offline
post #2 of 8 (permalink) Old 08-30-2002, 02:41 AM
no check engine light?
Warning: Object in mirror appears to be losing.
tegsled is offline
post #3 of 8 (permalink) Old 08-30-2002, 03:23 AM
Also can you explaine what the putters sound like?
XxGSRxX is offline
post #4 of 8 (permalink) Old 08-30-2002, 11:38 AM
MichaelDelaney's Avatar
Articles: 30
VTEC does not have 2 stages. It's on or off.
and in a GSR it is on at 4400-4500 rpm depending on loading conditions. in a GSR the "sound" at 5750 rpm is your IM secondary butterfly valves opening. If they do not open then you have a vacuum leak or the IAB solenoid is defective or the ECU wire to and from the IAB solenoid valve or the ECU itself is messed .
MichaelDelaney is offline
post #5 of 8 (permalink) Old 08-30-2002, 09:27 PM
Check your oil. Low oil pressure. This happened to me once. Hammered down VTEC engaged then disengaged at about 6000rpm. Make sure you have enough oil.
DJ 619 likes this.
1FSTGSR is offline
post #6 of 8 (permalink) Old 09-07-2002, 06:07 AM
along with 1FSTGSR said...if your car is lowered, and youve bottomed out, its possible that you could have dented your oil pan, inturn altering your screen, which will allow the oil to process slower which will inturn alter the oil pressure levels, which will inturn cause vtec to go in and out...inturn is such a fun word
tegsled is offline
post #7 of 8 (permalink) Old 09-07-2002, 02:33 PM
Articles: 30
what screen are you referring to?
the VTEC solenoid has a screen. It is nowhere near the oil pan. The oil panhas baffles but no screen. So i don't know what you are referring to....please clarify.
post #8 of 8 (permalink) Old 02-13-2015, 05:46 PM
I am having a similar problem I was wondering if this was ever fixed and if so what the problem was thanks....steve
AI95GSR is offline
