Need help - Team Integra Forums - Team Integra
post #1 of 6 (permalink) Old 04-08-2019, 01:36 AM Thread Starter
DPF
Need help
Is there something wrong because the piston is all the way up or i should be good ? As You guys can see the pistons dnt line up with the deck height ect i jist new bearing and pistoms ringa and arp bolts rods and main
ID:	80506   Click image for larger version
DPF is offline
post #2 of 6 (permalink) Old 04-08-2019, 05:29 AM
My brand new ITR piston has those marking. Did you use the clay method? That will determine your piston-valve clearance.
About time I can now apply for Historic Tags for my GS/VTEC Automatic and no more SMOG
In other news: New edition to the family born on August 21, 2018 @ 3:10am
phatintegra is offline
post #3 of 6 (permalink) Old 04-08-2019, 09:45 AM Thread Starter
DPF
Nop i didnt tht did the valve clearence
DPF is offline
post #4 of 6 (permalink) Old 04-08-2019, 11:59 AM
From what the picture shows, it is likely that the engine spun a rod bearing in that very cylinder. Hence the piston appears to be sitting a little below the deck. However, if all pistons seat equally below the deck surface may suggest that someone has been inside this engine before, lowered the compression by either using a various combination of pistons rods, crank - stroked it. In that case, you shall not experience piston to valve clearance issues, but will experience lower than normal compression (less power). However, if running a turbo, then I wouldn't even worry about it.
post #5 of 6 (permalink) Old 04-08-2019, 06:36 PM Thread Starter
DPF
Because i just rebuilt that engine i gonna go lsvtec nitrous
DPF is offline
post #6 of 6 (permalink) Old 04-09-2019, 08:40 AM
Please try and use proper punctuation/spelling, and complete sentences. Your replies make it extremely difficult to understand what it is you need. We should all be intelligent enough to form complete sentences when typing.
