98 gsr problems - Team Integra Forums - Team Integra
post #1 of 5 (permalink) Old 03-17-2019, 05:55 PM Thread Starter
98 gsr problems
I recently picked up a 1998 gsr pretty cheap but the guy i bought it from didnt tell me all the issues it had. He even went as far to remove the check engine light from the cluster to trick me...anyways it has a cylinder 3 misfire and it wont go away. Ive replaced spark plugs/wires, cap and rotor, fuel injectors, and fuel filter but to no avail. Any thoughts?
JustinG530 is offline
post #2 of 5 (permalink) Old 03-18-2019, 10:55 AM
Run a compression test and post back the numbers. Worse case scenario is you either have bad piston ring(s), burnt or bent valve, blown head gasket. Also make sure that your timing belt is set correctly.
post #3 of 5 (permalink) Old 03-19-2019, 06:43 PM Thread Starter
Compression test showed 210 140 200 210 ( left to right) and all the spark plugs were kind of blackish under the electrode.
post #4 of 5 (permalink) Old 03-19-2019, 08:06 PM
HeroOfTheDay's Avatar
That 140 on cylinder #3 is quite low in comparison to the rest. I'd say you have a mechanical issue, but a bore-cam or tear down are going to be the only ways to visually confirm it. You could always do a leak-down test, but it's a little more involved.
HeroOfTheDay is offline
post #5 of 5 (permalink) Old 03-20-2019, 06:17 PM Thread Starter
Ive decided im going to replace valves, seals, and springs...anything else worthwhile to replace while i have it apart? Dont have the money to rebuild yet so i havent tore it apart yet.
Similar Threads
99 Hatch unlock problems Crowder1974 Generation Three 1 02-11-2019 06:53 AM
