ls-vtec build - Page 2 - Team Integra Forums - Team Integra
 11Likes
post #15 of 20 (permalink) Old 09-09-2015, 09:42 AM
My lsv
My built lsv I just finished still gotta out the intske and stuff on and out it in the car.
B18b1 block
Wiseco 81.5mm 9.8:1 comp
Eagle rods
Acl main and rod bearings
Itr water and oil pump
Gates racing timing belt
Moroso oil pan
B16 head
Gsr cams
Stock valvetrain atm with titanium retainer.
Ls trans carbines lined synchros.
Good luck on your build.
derekhollister is offline
post #16 of 20 (permalink) Old 09-09-2015, 07:22 PM Thread Starter
JDR
JDR's Avatar
B18b1 block
Eagle rods
Moroso oil pan
B16 head
Gsr cams
Attachment 54498
Thanks bro with that low of compression im assuming you are going turbo. Are you on stock sleeves.
JDR is offline
post #17 of 20 (permalink) Old 09-09-2015, 07:24 PM
Ya stock sleeves and turboed. I plan on keeping it around 450 because of the stock sleeves.
post #18 of 20 (permalink) Old 10-05-2015, 01:26 AM Thread Starter
JDR
JDR's Avatar
Progress report
so my build is coming along I just acquired a b18 block good condition ill do a tear down to check the crank but all in all it is in good condition. Ill be sending the block to the machine shop to be preped for battle. These are some things I also acquired a Skunk pro manifold Alpha throttle body and a Aeromotive fpr . I bought a AEM but decided to go a little more all out.
ID:	55865   Click image for larger version
ID:	55873   Click image for larger version
ID:	55881   Click image for larger version
JDMJNKY and Geis like this.
JDR is offline
post #19 of 20 (permalink) Old 10-10-2015, 12:27 AM Thread Starter
JDR
JDR's Avatar
more parts
I had more parts come in today im not shure about the pie cut muffler ill have to see it on the car the cylinder is a little bigger then expected. And the function 7 lca are a piece of art.
ID:	56129   Click image for larger version
ID:	56137   Click image for larger version
ID:	56145   Click image for larger version
ID:	56153   Click image for larger version
JDR is offline
post #20 of 20 (permalink) Old 11-27-2016, 06:24 PM Thread Starter
JDR
JDR's Avatar
Progress
Finally made some progress by deleting the ABS and finished the wire tuck. I also droped the motor for a test fit and started the sun roof delete more on that latter.
ID:	71545   Click image for larger version
Name:	the beast.jpg
ID:	71553   Click image for larger version
ID:	71561   Click image for larger version
JDR is offline
