Engine cuts out at 3500rpm and low power - Page 2 - Team Integra Forums - Team Integra
post #15 of 17 (permalink) Old 05-02-2017, 05:42 PM Thread Starter
Josh044's Avatar
Alright I figured somethin in the distributor had to do with it, I also had put a new coil in because before I knew that the timing belt slipped I pulled the dist cap off and the plastic cover of the coil had cracked and I thought that might of been the starting issue.
Josh044 is offline
post #16 of 17 (permalink) Old 05-03-2017, 07:14 AM Thread Starter
Josh044's Avatar
So found the ecu, thanks for the pointers. I got blink code 4- crank angle sensor so hopefully the distributor will take care of that.
Josh044 is offline
post #17 of 17 (permalink) Old 05-05-2017, 12:01 AM Thread Starter
Josh044's Avatar
New distributor took care of it, runs great now.
Josh044 is offline
