Throttle cutting out - Team Integra Forums - Team Integra
post #1 of 3 (permalink) Old 01-15-2019, 05:26 PM Thread Starter
Hey I’m new to this site I was wondering if anyone can help me with a issue my integra is having so basically it runs fine when the car is cold. but once it warms up the throttle will cut out when I accelerate and it will have trouble keeping the idol up it only seems to cut out below 2500 rpms it runs strong when the RPMs are really high which makes me think it’s not a fuel pressure issue but Idk I replaced the fuel pump because it went bad this problem started a week after putting the new one in also replaced the TPS sensor cleaned the throttlebody got new vacuum hoses and replaced the iacv. does it sound like if your pressure issue??
hondagang is offline
post #2 of 3 (permalink) Old 01-17-2019, 02:22 PM
Correctly adjust TB cable.
post #3 of 3 (permalink) Old 01-29-2019, 07:13 PM
alittlewantto's Avatar
Check your injector o rings and seals also replace them if you haven't already if you have sometimes they still need a slight twist to seat properly
alittlewantto is offline
