93 gs valve adjustments - Team Integra Forums - Team Integra
  • 1 Post By Kaelorr
post #1 of 8 (permalink) Old 09-05-2015, 12:59 AM Thread Starter
So I've heard plenty of things regarding adjusting intake/exhaust valves to perform better than oem specs. Need just a little information so I can get a little more (if possible) out of my fresh rebuild. Thanks.
93_itegasm is offline
post #2 of 8 (permalink) Old 09-05-2015, 01:08 AM
JDR
JDR's Avatar
valves
Originally Posted by 93_itegasm View Post
So I've heard plenty of things regarding adjusting intake/exhaust valves to perform better that oem specs. Need just a little information so I can't get a little more (if possible) out of my fresh rebuild. Thanks.
If your valves are ticking then they need to be adjusted it will make care have a smoother idle and run a little better . If they are not leave them alone wont do any thing. you need a feeler gauge to do this if you never have done a valve adjustment I would not recommend you doing it take it to a shop
JDR is offline
post #3 of 8 (permalink) Old 09-05-2015, 01:26 AM Thread Starter
I already adjusted my valves because I just swapped a new head on it. I was asking for some truth behind opening valves for the intake more or exhaust more. Just wanting to know if it actually does anything because I hear of people doing it all the time to their Hondas
post #4 of 8 (permalink) Old 09-05-2015, 02:20 AM
JDR
JDR's Avatar
As far as my knowledge goes and some one correct me if im wrong but you all ways refer to the oem spec settings for the application you are working on.
JDR is offline
post #5 of 8 (permalink) Old 09-05-2015, 02:22 AM
JDR
JDR's Avatar
I think your confused with cam timing lol
JDR is offline
post #6 of 8 (permalink) Old 09-05-2015, 07:04 AM Thread Starter
Yeah yeah, you got it. Couldn't remember it was something with the valvetrain. But yeah how would I go about timing my cams for them to stay open longer on the exhaust side? I have skunk cam gears.
post #7 of 8 (permalink) Old 09-05-2015, 07:32 AM
Kaelorr's Avatar
Adjustable gears won't change valve duration, just timing. You might want to leave that to someone with some tuning experience. You can cause some expensive problems if you play around with cam timing. If you just have adjustable cam gears on an otherwise stock engine, you won't get anything from adjusting them anyway; small gains in one part of the power band will mean a big loss in another part.
JDR likes this.
Kaelorr is offline
post #8 of 8 (permalink) Old 09-06-2015, 03:38 PM
Shuudoushi's Avatar
Increasing valve lift would be done by the size of the cam lobe, i.e. you need a different cam. BC 403s (I think that's the right ones at least) will be your best bet, not much out there in the aftermarket for non v-tec heads...
Shuudoushi is offline
