Low Idle , Feels like its dying - Page 3 - Team Integra Forums - Team Integra
post #29 of 38 (permalink) Old 03-13-2007, 03:05 PM
Well, come to find out in my situation it just happened to be as simple as a bad number one sparkplug wire.
StreetDemon94LS is offline
post #30 of 38 (permalink) Old 03-14-2007, 10:14 PM
what you need to do is try changing the fuel filter.
Enthusiast is offline
post #31 of 38 (permalink) Old 03-21-2007, 10:35 PM
mine was idling really low so i was looking around and the electrical plug to the FITV was unplugged, id check that its a possibility
jaggednext is offline
post #32 of 38 (permalink) Old 07-15-2007, 09:00 AM
when i first start my car in the morning, it revs from 2.5-3.5. yesterday morning i was cleaning my ABS sensor. so my car was on a jack and the left wheel was off. i started my car with the car jacked up and when it was reving 2.5-3.5 the left wheel was spinning. is that normal? after it warms up, the reving stops but my car feels like it's about to die. very shaky. any ideas? help please <33 replies = thank you.
unkn0wnintegra is offline
post #33 of 38 (permalink) Old 07-16-2007, 09:06 AM
TurboLS's Avatar
Articles: 7
Feedback Score: 22 reviews
If your car is jacked up in the front, your wheels will spin out of gear at idle. This is completely normal. As for your car about to die, what you are experiencing is the shift between the throttle plate closing and the IACV taking over once the engine gets back down to idle speeds. you will notice a "low spike" when you rev and let off before the IACV opens. This is greatly exaggerated when your oil temps are relatively high as well.
TurboLS is offline
post #34 of 38 (permalink) Old 08-12-2007, 12:03 PM
ChibiT89's Avatar
Hey all, i have a similar problem but with diff symptoms:
- during throttle, not "all" of the power is there as acceleration is slow (i had to take the car home)
- feels/sounds like a go cart (i need to replace b-pipe, but the sound sounds more awful now)
- car is shaky, feels like it will die @ stoplight (but never does)
- idle is the same way (during park)
From reading, i can change plugs, wires, alt, and/or clean IACV.
Also, why would changing my fuel filter help anything? even if the filter is "clogged" up lets say, it can effect performance? i've changed my filter but i feel i could change it again.
I've cleaned the IACV not too long ago, so i don't think that's an issue (I had a low idle problem but it was fixed)
any thoughts?
thank you.
94 LS Black - 111k miles and still going (somehow)
04 RX-8 Winning Blue - 30k miles (my other baby)
08 Kawi Ninja 250r Red 6k miles (euphoria on 2 wheels)
ChibiT89 is offline
post #35 of 38 (permalink) Old 08-12-2007, 03:30 PM
TurboLS's Avatar
Articles: 7
you can also check vacuum. some times a leak will cause odd issues.
you can also check ignition timing.
if you're having acceleration problems it could be ignition related or possible fuel related, like a clogged fuel system, bad O2 sensor, etc.
fuel filters are technically supposed to be replaced every 30k too.
TurboLS is offline
post #36 of 38 (permalink) Old 10-02-2010, 07:42 PM
Hi, i'm also haveing the same issue with the idle, first of my car is a 94 ls and when idle when warm it idles fine but sometimes the rpm drops low then shoots back up to normal again, is this normal? i'm just afraid the car is gonna stall out when i'm at a red light or something, i've looked into everything from the iacv to the fitv to adjusting the idle, any help would be appreciated thanks....
06rtl is offline
post #37 of 38 (permalink) Old 12-04-2010, 12:08 AM
hi, im having a same problem to my 99 integra ls and i think i found a solution about low idle and high idle..it need to change my catalytic converter bcuz i recently bought a aftermarket headers and exhaust and my converter is stock so i might probably need a magnaflow catalytic converter since i have a all aftermarket header, exhaust, and muffler..and i also tried adjusting the IAC and resetting the ECU and even disconnected the battery and my car still sounds its dying whenever it hasn't warmed up but when its the engine warmed up my car sounds normal and everything.
edwardsolomon is offline
post #38 of 38 (permalink) Old 03-27-2019, 01:15 PM
When I put my car into first gear and I go to take off it stutters like it’s going to die then goes back to being normal but starts to take forever to build up speed. Anyone know what might be wrong?
Anthony Cisneros is offline
