Acura Integra rear wheel hub replacement - Team Integra Forums - Team Integra
post #1 of 4 (permalink) Old 06-05-2019, 09:02 PM Thread Starter
Hello,
I bought a pair of rear wheel hub assembly for my 99 Acura integra. One of the hub had the inner cover was loose and came off exposing the actual ball covered in grease. My question is, is this a defect or is it still good to use? Thanks
HelpmePlease is offline
post #2 of 4 (permalink) Old 06-06-2019, 11:00 AM
You don't want dirt contamination inside there in my opinion.
post #3 of 4 (permalink) Old 07-02-2019, 11:27 AM
I'd put RTV/Silicone Caulk on it, and use it like that.
In my case, it seemed the rod on the trailing arm had a longer diameter than it should have.
2001 Integra GS Automatic Coupe; B18B1: 240,000 miles.
k3ntegra is offline
post #4 of 4 (permalink) Old 07-05-2019, 09:49 AM
deesautohouse's Avatar
It'll be fine, but it will probably have a shorter life span. I've had the same issue happen to myself a few times. They still last at least 5 years unless you are doing something extreme.
Previously: mr2lickit (lost account)
Cars:
2000 Integra GSR - Stolen
1995 Integra RS
deesautohouse is offline
