2000 Integra LS charging system not working???? - Team Integra Forums - Team Integra
post #1 of 2 (permalink) Old 05-26-2019, 11:37 PM Thread Starter
Exclamation 2000 Integra LS charging system not working????
I can't figure out what the problem is with my integra. It has the exact same problems as the *fuse 15 popping/blowing* but there are no blown fuses or shorts in the wiring. The secondary o2 sensor did short out against the heat shield, but I removed the o2 sensor so there shouldn't be anything causing the problem unless if that cause the ECU to fry. I've checked all of the wiring and there are no exposed wires/shorts that i can see. I've replaced the alternator twice, battery, perfectly fine fuses. I've been trying to figure the problem out for almost two months now and its really getting on my nerves because it should have been solved. I know that the alternator is ran in the same circuit with the VSS, Secondary o2 sensor, 3 EVAP things and the ECM/ECU. I'm at a standstill now, and don't know what to do. Do you guys think it could be an ECU issue? I really miss driving my integra so any help would be appreciated! Please let me know if there's anything i could be possibly missing something out of this post!
Casey Aquin is offline
post #2 of 2 (permalink) Old 05-28-2019, 02:45 PM
If you think its ECU related, then remove it, open both lids and inspect the circuit board. Replacement ECU is $99 on ebay
Similar Threads
2000 Acura Integra LS nimbus2000_db7 Generation Three 4 08-23-2018 12:37 AM
Florida - [SOLD]: 2000 Acura Integra GS-R | Turbo | JDM Conversion [CHLOE] - IMPORTEKNIKAICR For Sale and Wanted - Cars 32 03-26-2018 07:27 AM
- IMPORTEKNIKAICR: 10? Make That 18 Years of Integra! - IMPORTEKNIKAICR Your Integra 29 02-27-2018 10:26 AM
