96 gsr wire harness - Team Integra Forums - Team Integra
post #1 of 8 (permalink) Old 05-17-2019, 12:22 PM Thread Starter
96 gsr wire harness
I need help identifying these connectors on my harness. The harness was cut up when i got the car.
First connector has 1 solid green wire and a red wire with white stripe
Second is a solid yellow wire and a green wire with black stripe
Third is a blue wire with red stipe and a white wire with red stripe
Last one is 1 solid green wire and 1 solid black wire
ID:	80666   Click image for larger version
ID:	80668   Click image for larger version
ID:	80670   Click image for larger version
RhdDb8 is offline
post #2 of 8 (permalink) Old 05-17-2019, 12:30 PM
danteisme's Avatar
which harness is this? i might be able to help, i have most of my car torn apart right now replacing a harness.
Bloggity Blog
danteisme is offline
post #3 of 8 (permalink) Old 05-17-2019, 12:31 PM
Absolute_Yeti's Avatar
first thing that would help would be the locations these came from (engine bay, dash area, trunk, etc.) Some of those connectors and colors are common throughout the car.
B18b1
Absolute_Yeti is online now
post #4 of 8 (permalink) Old 05-17-2019, 06:26 PM Thread Starter
This is from the engine bay
RhdDb8 is offline
post #5 of 8 (permalink) Old 05-17-2019, 08:59 PM
danteisme's Avatar
Which side? A good portion of the passenger side harness of the engine bay is part of the cabin harness.
post #6 of 8 (permalink) Old 05-18-2019, 11:26 AM Thread Starter
If anyone has a 96-98 integra can you check what color wires your iat,ect, and fan switch is!!!
RhdDb8 is offline
post #7 of 8 (permalink) Old 05-18-2019, 11:29 AM
popanollie's Avatar
the second connector is the backup light switch. the switch end of the connector should have 2 green wires and be located on the front of the transmission by the vin stamps. the fourth connector is the coolant temp sensor and is located in the back of the engine between the starter and intake manifold, in the thermostat housing. the other two are either on the underside or located somewhere else, or came off another cat to be used for other sensors. i need to change my oil soon and will look for the other two and get back to you
popanollie is offline
post #8 of 8 (permalink) Old 05-18-2019, 02:37 PM Thread Starter
Thanks bro
RhdDb8 is offline
Similar Threads
BuiltNoTboughTdc2 1/8-mile vs. Hellcat Built_not_bought Forced Induction 221 06-10-2019 11:05 AM
1996 integra with b20 swap missing ECT gauge sending wire Bere7 Audio, Security and Electrical 0 03-14-2019 10:15 PM
2000 gsr harness swap into 98 ls Shawn Earp Audio, Security and Electrical 1 09-17-2018 09:12 AM
Engine harness probs Casey Ryder Generation Two 0 06-25-2018 11:00 AM
Help- O2 sensor wire harness continuity Jester14 Generation Three 0 05-03-2018 10:47 PM
