98 LS not getting Spark - Team Integra Forums - Team Integra
post #1 of 3 (permalink) Old 04-03-2019, 07:21 PM Thread Starter
Magically on the way home car quit. Would not start. Battery was really weak so I replaced. Still would not start. Took spark wire out to test spark. When I did that the car started. So, I replaced the rotary button and The distributor cap. When I did that it cranked up and ran for about four minutes and then stop and will not start back.
Replaced distributor today and did not work either. Pulled wire out put plug in it and tested to see if I saw a spark or an arc. Nothing.
What could it be? Some ground somewhere?
Sent from my iPhone using Tapatalk
anoble1 is offline
post #2 of 3 (permalink) Old 04-03-2019, 11:27 PM
Did you check the resistance across your coil?
Do a search and it's easy to check and replace, if needed.
stlcounty is offline
post #3 of 3 (permalink) Old 04-04-2019, 10:20 AM Thread Starter
Dang. Stupid fuse under dash for ignition.
anoble1 is offline
Similar Threads
GSR not starting after changing ICM, fuel and spark present broodyr Generation Three 7 04-03-2019 09:59 PM
94 LS Auto bogs/rich smell/horrible mpg/have to take foot off gas to shift into 4th Binkoama Generation Three 1 03-21-2019 12:35 PM
Please help me, my integra isn't running and hasn't ran since 2016 1993AcuraIntegra Generation Two 3 10-24-2018 12:45 PM
Oil in spark plug wells... Mister.X Performance 3 10-12-2018 08:23 AM
99 acura integra automatic i did something stupid no fuel or spark Cali Cortez Generation Three 3 07-25-2018 05:59 PM
