even more noise after valve leash - Team Integra Forums - Team Integra
  • 1 Post By androsk
post #1 of 6 (permalink) Old 02-26-2019, 08:49 PM Thread Starter
androsk's Avatar
hi guys, i did today my valve leash on b18b1, because there was some noise form valves in the morning first star, after warm up the noise gone. i used this specs, let the car sit cold overnight.
B18B1 engine:
Intake-0.003-0.005 in. (0.08-0.12mm),
Exhaust-0.006-0.008 in. (0.16-0.20mm)
used 0.003 to IN the feeler 0.004 cant get in
used 0.006 to EX the feeler 0.007 cant get in
followed the tutorial from TI, also watched some videos, and i am positive that did ir right, checked clearance 3 times. there is small amount of drag on the feeler on every valves manual indicated.
and now the noise is worse it doesn't even go away when warm up now.
should i go below spec?, should i put even more drag on the feeler, that barely can pull it out? i am very frustrated, i am good with mechanic, everything go right the first time usually, but valve leash.
any suggestions?
androsk is offline
post #2 of 6 (permalink) Old 02-27-2019, 12:28 AM Thread Starter
androsk's Avatar
Update: my block says b18b1 the head says pr4-1 is this the head I should have? Or previous owner replaced?
androsk is offline
post #3 of 6 (permalink) Old 02-27-2019, 02:52 PM Thread Starter
androsk's Avatar
Update: i been working the valves again all the morning and think i found the issue, i was "feeling" with the feeler gauge over the jam nut, not from the sides, in the EX it even fit the 0.011,
ill update again once im done
androsk is offline
post #4 of 6 (permalink) Old 02-28-2019, 10:29 PM Thread Starter
androsk's Avatar
Update: fixed, it's purrs again as it should.
JH4DC2Man likes this.
androsk is offline
post #5 of 6 (permalink) Old 03-07-2019, 10:46 AM
surfinrat's Avatar
Man, I did the same thing a few years ago when I did my rebuild. Glad you figured it out!
Stock 01 Silver GSR [Sold ]
surfinrat is offline
post #6 of 6 (permalink) Old 03-19-2019, 12:50 AM Thread Starter
androsk's Avatar
ikr, it almost dive me crazy since i checked like 6 times and was sure i did it how i saw in the videos.
androsk is offline
Similar Threads
Stuttering, Missfiring, popping noise, horrible etc sheisavirgo Performance 14 12-22-2018 10:28 PM
Integra no crank/no noise situation. W Video tajboy123 Generation Three 1 09-06-2018 06:45 PM
Bizarre Squealing Noise -- 1998 Integra LS B18B1TeggyMike Generation Three 3 07-22-2018 09:21 AM
Need Help With Replacing Vapor Canister and Valve stolz Generation Three 1 06-03-2018 09:49 AM
Adjustable proportioning valve and non ABS install 8luedragon Generation Three 2 03-14-2018 06:40 PM
