Starting problem 01 gsr - Page 2 - Team Integra Forums - Team Integra
 2Likes
post #15 of 30 (permalink) Old 08-04-2016, 12:29 PM Thread Starter
Or are you saying the new one is bad
bobandcar is offline
post #16 of 30 (permalink) Old 08-20-2016, 03:54 PM Thread Starter
The green key deos not blink or light up when I turned the key and it didn't start.
I took the starter off and took it to autozone and they gave me a new one under warrenty.
Just replaced and turned car off and on multiple times. 10 maybe. So far no issue but I'm not getting my hopes up.
Ground wires. The one from the radiator support to the head(I think) has some corrosion in the wires. Also from the tranny to the passenger side strut tower has some corrosion. Not bad but I guess they are probably cheap to replace. Suggestions?
The thermostat is just below the throttle body, right? There is a bolt with 2 wires going to it. Is that a ground? They don't look to bad.
post #17 of 30 (permalink) Old 09-01-2016, 11:47 AM Thread Starter
Probably put the starter thru 30-40 cycles already and started every time
Should I be looking to replace those grounds?
post #18 of 30 (permalink) Old 09-01-2016, 12:31 PM
Are they corroded or frayed? You should be able to look yourself and see if they need replaced or not.
post #19 of 30 (permalink) Old 09-01-2016, 05:08 PM
blandsarcasm's Avatar
it sounds like either the starter itself was bad or there was an intermittent connection to it.
blandsarcasm is offline
post #20 of 30 (permalink) Old 09-04-2016, 11:02 AM Thread Starter
Starting problem 01 gsr-imageuploadedbyag-free1473001326.921689.jpgnear passenger side wheel well front.
What is this trans mount called?
post #21 of 30 (permalink) Old 09-04-2016, 11:32 AM Thread Starter
Corroded partly for the ground wires
post #22 of 30 (permalink) Old 09-05-2016, 01:37 AM
dpaton's Avatar
Attachment 68681near passenger side wheel well front.
That's the passenger side torque mount.
dpaton is offline
post #23 of 30 (permalink) Old 09-06-2016, 06:22 PM Thread Starter
Guess just go oem?
Is there a difference in LS vs GSR vs type r? Are they interchangable?
post #24 of 30 (permalink) Old 09-06-2016, 06:58 PM
i just filled in the old mounts with dow window weld.
a bit messy but works great and cheap as hell (my main mantra).
2 Dow U 428 Plus Windshield Urethane Primerless Adhesive Glue Sealant Window | eBay
wino is offline
post #25 of 30 (permalink) Old 09-07-2016, 06:14 PM Thread Starter
If it wasn't broke. Then I would entertain that idea
post #26 of 30 (permalink) Old 09-12-2016, 08:29 PM Thread Starter
So I bought a full set of mounts. All 5. They are cheap ones as money is tight. I havnt checked the rest so I don't know if I need them or not but I grabbed them.
Would it be beneficial to me to use the window sealant now before even putting them in.
post #27 of 30 (permalink) Old 09-13-2016, 06:57 AM
This statement is starting to side-track from the original issue and point of your thread. I suggest changing the title to reflect the idea of starting a personal build thread.
But, I wouldn't start asking questions about engine mounts in a thread about your car not starting.
m_haiser likes this.
post #28 of 30 (permalink) Old 09-13-2016, 08:24 PM Thread Starter
How do I change the title? When I push edit it only lets me change the individual post
