Rear taillight gasket discussion - Team Integra Forums - Team Integra
 2Likes
  • 2 Post By joron
post #1 of 10 (permalink) Old 10-09-2015, 08:19 AM Thread Starter
bcnotebook3's Avatar
DMT Honda Improved Material 94 01 Acura 2dr Taillight Gasket Gaskets Set Pair | eBay
Anyone have any feedback or a review on these or recommend a brand/company who makes them better than factory
bcnotebook3 is offline
post #2 of 10 (permalink) Old 10-09-2015, 08:54 AM
knavekid's Avatar
I haven't used them, but I plan to get the Detroit Muscle taillight gaskets for my RSX the next time I replace them base on this post:
https://www.team-integra.net/forum/11...ml#post3251665
I have found the OEM gaskets on my RSX get stiff and leak after about 5 years. Perhaps the material used by Detroit Muscle will hold up better. At this price, it is worth a try.
knavekid is offline
post #3 of 10 (permalink) Old 10-09-2015, 09:17 AM
I compared the detroit muscle gaskets with the OEM gaskets that are about a year old and the detroit muscle gaskets are noticeably thicker than the oem gaskets. Mine weren't leaking from the gaskets this summer (previous summer they were moist/leaking) I was still getting a ton of leaks on the sides of my trunk.
The thread posted by @knavekid I believe also fixed my leak, I never replaced mine with oem (entered the wrong CC, lol) and am using the gaskets from Ace and it has rained a few times and my trunk has been dry. The original gaskets on those pieces broke apart when I took them off the car.
aw614 is offline
post #4 of 10 (permalink) Old 10-09-2015, 10:23 AM
just a thought, since I have been researching sound deadening for my teg, I came across second skin audio OverKill Pro™ 9 sq. ft - 1 sheet - Second Skin Audio
This closed cell foam is probably the same foam as OEM but for 30 bucks at 9 sq ft. not a bad deal
Water leaks fixed for now. Working on getting body back to OEM.
macura2001 is offline
post #5 of 10 (permalink) Old 10-09-2015, 09:09 PM
MKZAcura's Avatar
I used an old wet suit that I had laying around for my taillight gasket, its been 3 years so far so good.
MKZAcura is offline
post #6 of 10 (permalink) Old 06-14-2016, 09:39 PM
I ordered and installed the DMT gaskets and am very impressed with the quality. They shipped quickly and solved my leaky taillight problem. Much less expensive than Acura OEM version. Recommend!
knavekid and m_haiser like this.
joron is offline
post #7 of 10 (permalink) Old 09-05-2016, 08:18 PM
I have a taillight gasket leak , I DEFINETLY know its coming from the taillights. I ordered the Detroit muscle taillights and new Left and Right grommets, I put everything back together. Later I washed the car and again I have water in my trunk. I put them how they should go. Idk what I'm doing wrong mybe overtightening the bolts ? Do I have to use glue or something? How much do you have to tighten the little screws?
blackandtanteg is offline
post #8 of 10 (permalink) Old 09-06-2016, 07:32 PM
knavekid's Avatar
Until you know exactly where the leak is, it will be hard to diagnose the problem. You might try removing the leaking taillight and see if you can see an area on the gasket that is not compressed where it might not be making a seal. If you can't see anything suspect, dust some talcum powder on both sides of the gasket before reinstalling the taillight. Put some paper towels around the inside of the car below the taillight to absorb any leakage. Pour water over the top of the taillight and observe the paper towels are getting wet. Then remove the taillights and see where any of the powder is wet or washed away. This should identify the path the water is taking.
Once you figure out the leak path, you can then figure out the fix.
knavekid is offline
post #9 of 10 (permalink) Old 09-06-2016, 11:36 PM
I didn't do what you mentioned above because I put everything back on before I seen this post. Ill see if it leaks again next time I wash the car. I hand tightened the screws as tight as I can and I made sure the gasket was as flush as I can get it.
However I did notice when I took it off that inside the left taillight was water in it; also on the foam gaskets themselves they were wet. I also noticed when I put everything back when I look face down from the trunk area onto the taillights that the left taillight sticks out more than the right by just a little bit. Its the hard rubber piece I'm talking about on top of the taillight. I hope that makes sense. Only time will tell next wash.
post #10 of 10 (permalink) Old 06-17-2017, 06:19 PM
just wanted to update my leak it was from the taillight lens, the gasket, rear windshield nozzle gasket, seal on the inside of trunk was cracked, and that's about it
