93 DA into 94 DC swap - Team Integra Forums - Team Integra
  • 1 Post By JDR
post #1 of 5 (permalink) Old 09-30-2015, 01:33 PM Thread Starter
So, I have a 93 da my girl and I bought as a project car. It is rusted to all hell and instead of screwing with the body work I was going to swap it into a clean shell. I can't find a clean da in my area but I found a clean 94 that I can get for a killer deal. Will the motor and tranny from the da just drop right into the 94 since they are both b series? Or what do I need. I'm new to the Honda game.
that.subie.punk is offline
post #2 of 5 (permalink) Old 10-09-2015, 08:16 AM
bcnotebook3's Avatar
I believe you might need different mounts and maybe a different header (dont quote me on it)
you'll need a obd1 ecu, (if someone dident swap out the harness to a obd2 already) and the 94 engine harness etc, shift linkage i know between the two are almost the same between the models but they are also slightly different in the bends in the pipes. Other than that you shouldn't have a real big problem. Just make sure you have the t-bracket for the rear mount, and the tranny bracket to the side mount that bolts to the bottom on the engine bay and i would get the ac bracket and mount for the other side just because honda intended it for a reason. Ill take pictures of my engine bay if you need them.
bcnotebook3 is offline
post #3 of 5 (permalink) Old 10-09-2015, 11:29 AM
also axles....
post #4 of 5 (permalink) Old 10-09-2015, 11:29 PM
JDR
JDR's Avatar
da have cable trans
bcnotebook3 likes this.
JDR is offline
post #5 of 5 (permalink) Old 10-10-2015, 08:56 AM
Originally Posted by JDR View Post
da have cable trans
( totally forgot )
yeah you need the conversion kit to make the tranny work as well
