water leak not your common ones. - Page 4 - Team Integra Forums - Team Integra
 4Likes
post #43 of 45 (permalink) Old 02-04-2016, 02:20 AM
I have water leaking at the inside top of my hatchback. Any suggestions with this? And pools in my tire well that seems mostly dripping at the rear left corner but nothing behind any of the paneling seems wet.
ID:	61009   Click image for larger version
ID:	61017   Click image for larger version
stvpourciau is offline
post #44 of 45 (permalink) Old 02-04-2016, 02:43 AM
So I recently changed out my tail light gaskets cause I thought they were leaking, but it turns on on the rear driver side, there's a vent, and water was coming in through the sides of that vent... I bought some black silicone and put it around the border of the vent and now there's no more leaks... check out that vent... good luck
boostaddctn is offline
post #45 of 45 (permalink) Old 02-04-2016, 07:55 AM Thread Starter
really hard to tell where your water is coming from in those pics. you really just have to trace it up. are your rear side panels out?
if you have water in spare tire area, most likely bad tailight gaskets, separated seam along hatch opening, or sunroof drains. kidwilson had body cracks along inside of his taillight recess. watch his videos. you need a dry day and time to figure out where its coming from and read this thread front to back.
if water is under your rear seat, most likely coming from loose rear washer nozzle, cracked body seams at roof and side panel, rubber grommet for wiring on right side not seated correctly.
goodluck to ya
Water leaks fixed for now. Working on getting body back to OEM.
macura2001 is offline
