Engine stuttering, white smoke and gas smell from exhaust... - Page 2 - Team Integra Forums - Team Integra
post #15 of 15 (permalink) Old 03-31-2019, 04:43 PM
I had an issue like this with my 94 LS with 284k miles. I solved it by retorquing the head.
I rebuilt my engine and things were working fine. At maybe 500-600 on the rebuild it sputtered on startup and took maybe 15 seconds to clear out and run normally.
Then it wouldn't start after shutting it down when hot. If I left it sit all night and it was cool it would start but sputter and them steam slightly out of the exhaust for a few minutes.
If it wouldn't start I could pull the plugs and clean them of the coolant which was fouling them. Another thread said that the head was under torqued.
In my case, I reused the head bolts. The threaded bolts holes and the bolt threads were totally clean and dry when I installed them. I noticed when torqueing them that they made a few little creaks right before full torque. My machinist/mechanical engineering friend said that this was friction on the threads and was preventing the bolts from creating the full clamping force on the head.
So I pulled them out and oiled and torques them one-by-one starting with the last bolt in the tightening sequence. This has apparently solved the problem. The car starts normally after hot shutdown.
I didn't have any other problems associated with blown head gaskets like oil/coolant mixing or rough running.
guitarswheelies is offline
