Team Integra Forums - Team Integra - View Single Post - CA 1998 Milano Red GSR SOLD
post #1 of (permalink) Old 06-07-2016, 05:38 PM Thread Starter
HawaiianLaker
HawaiianLaker's Avatar
UPDATE! SOLD!Hey guys, it's been real, but I don't have a use for 2 cars so it's time to sell the Integra. It has a clean title and 171k miles on it. About a year ago I had a major service done on it which included:
-CAM SEALS
-REAR MAIN SEAL
-CAM PLUG
-DIST O’RING
-WATER PUMP
-VALVE COVER GASKET SET
-LEFT FRONT POWER ENGINE MOUNT
-TIMING BELT
-ALTERNATOR BELT
-POWER STEERING BELT
-A.C. BELT
The car also as some aftermarket parts installed.
-Sony head unit
-Infinity Basslink 10'' Sub/Amp combo
-AEM Short Ram Intake with CARB sticker
-DC 4-2-1 Ceramic Header with CARB sticker
-DDM Tuning HID kit
-Koni Yellow Struts
-Ground Control Coilover sleeves
-Python 2-way alarm
With that done the car runs great but still needs some love.
-Paint is in bad shape, I was always a function first type of guy so it didn't bother me but it needs to be resprayed.
-Driver side window doesn't work as the switch died. I have a new one but haven't put it in.
-The Python alarm that I had installed back in 08 is stuck in valet mode. I tried to reset it but didn't work so its pretty much a keyless entry now.
-Hatch lever doesn't work, needs to be opened with key.
-Clutch needs to be replaced. works but you can hear the rivets every now and again.
-Oil pan leaks a little bit, needs gasket.
-Someone hit the front driver side corner when it was parked which broke the headlight tabs. the light works but its pointing at the ground as its not held up anymore.
-Power steering leaks. have not confirmed whether its the pump or the lines or what but its a small amount.
-Someone tried to steal the car last week and broke off the driver side door handle...
Let me know what you guys think! Reply or PM.
Asking: $3000
ID:	65746   Click image for larger version
ID:	65754   Click image for larger version
ID:	65762   Click image for larger version
ID:	65770   Click image for larger version
ID:	65786   Click image for larger version
ID:	65794   Click image for larger version
ID:	65802   Click image for larger version
HawaiianLaker is offline
