Will these rims fit my 94' gsr? - Team Integra Forums - Team Integra
 2Likes
  • 1 Post By dpaton
  • 1 Post By rektilian
post #1 of 12 (permalink) Old 06-07-2016, 01:27 PM Thread Starter
I've been looking at some new rims and the rims i've found that i like are the
16x7.5 Konig runlite rims.
half of the sites say they fit my model and half say they dont. can somebody please tell me if these measurements will fit?
Bolt Pattern: 4x100 Bolt Pattern
Hub Bore: 73.1mm Hub
Offset: +45 Offset
Manufacturer Part Number: R176100457
thank you for your help!
rektilian is offline
post #2 of 12 (permalink) Old 06-08-2016, 08:51 AM
Yes, they'll fit fine. All the dimensions you have listed above will work.
post #3 of 12 (permalink) Old 06-08-2016, 05:49 PM
the +45 offset won't be too close to the trailing arm?
aw614 is offline
post #4 of 12 (permalink) Old 06-08-2016, 09:07 PM
+45 is the ideal offset. In fact, it's the offset on the factory OEM wheels.
post #5 of 12 (permalink) Old 06-08-2016, 09:18 PM
dpaton's Avatar
+38 is the offset on my fat fives and my meshies.
My FS thread
dpaton is offline
post #6 of 12 (permalink) Old 06-08-2016, 09:27 PM
You would be correct. When I did a quick search, I found the +45 was for the OEM 16" R wheel.
I believe Honda used a few different offsets for their OEM wheels throughout the years.
post #7 of 12 (permalink) Old 06-08-2016, 09:31 PM
dpaton's Avatar
The OEM 16" ITR wheel is a 16x7, while OEM 15" rims are 15x6. That would push the offset 7mm between the two.
dpaton is offline
post #8 of 12 (permalink) Old 06-08-2016, 09:35 PM
You realize that math was never my friend, right?
post #9 of 12 (permalink) Old 06-08-2016, 11:30 PM
But based on the tire and wheel calculators, the wheel will sit further in, just wasn't sure on the 7.5in width at that offset, I remember from another post, the 949ul with the same width clears, but they are et42 or et43. So if it doesnt clear the rear worst case would be a 3mm spacer.
I thought the oem 15x6 wheels were +45
aw614 is offline
post #10 of 12 (permalink) Old 06-09-2016, 12:33 AM
Shuudoushi's Avatar
I have 16x7 with a +40 offset rims on my DA, and while running 40-45 profile tires, I ended up using 1 inch spacers on the front to keep from destroying the inside edge of my tires.
Just food for thought.
But if you really aren't sure, find a buddy or something/someone with wheels of a similar spec and put one or two on the front. turn the wheel full lock in one direction, check the clearance, then turn the other way and check again. Make sure to check both the leading and trailing edge of the tire to make sure it's not going to rub like a mofo.
Shuudoushi is offline
post #11 of 12 (permalink) Old 06-09-2016, 10:28 AM
dpaton's Avatar
You made a liar out of me. My spare fat five in the basement has 15x6 JJ 45 stamped on the lip. My bad.
Shuudoushi likes this.
dpaton is offline
post #12 of 12 (permalink) Old 06-10-2016, 02:02 AM Thread Starter
okay, thanks for the feedback. gonna order them next paycheck!
