Adding this thread to track modifications and report success/failures of those mods and my merry band of racer wanna-be's.
I bought this car recently. It was already built as you see here. I will race it in the World Racing League Texas and Oklahoma region races. My race team is JoBo Racing. We have raced a '93 Mazda 626 in LeMons, Chump, and WRL for the past 3-4 years.
Here's some quick specs on the car as I bought it:
I am now prepping the car for the WRL event at Hallett Motor Racing Circuit on Oct 22-23. Here's the list of prep items I hope to complete before the race:
- 1.8L B18A1 w/beefed up lower end and stock head. I don't know the details, but as cheap as I got this car, it's not important. It seems to be well put together
- Factory LSD
- Hondata
- 5 speed
- Header
- AEM fuel rail
- Koni coilovers with Eibachs
- K1 wheels with almost new Yoko A048 225/50-15
- Fuel Safe cell inside containment box (firewall)
- 3 qt Accusump
- Proportioning valve
- All steel braided lines
- 5L ESS Fire system with nozzles @ cell, driver and engine bay
- Ultrashield containment seat on slide with adjustable back brace
- OMP 6-point harness (through 2017)
- Window net
- Fiberglass flares and custom seamless nose with ducting
- SCCA-legal air dam
- Lexan windshield
- Carbon fiber hood
- Freshen brakes: New pads (Hawk DTC-60's), rotors (Centric High Carbon), and calipers
- Inspect and replace front upper and lower ball joints and outer tie rod ends as needed
- Inspect and replace suspension bushings as needed. Bought a complete set of Energy Suspension bushings including the rear control arm bushings
- Replace badly worn shifter linkage and bushings
- Install an ASR rear sway bar
- Create a template for the air dam/splitter (so I can build a new one after we accidentally destroy this one)
- Freshen fluids: Brake Fluid, Engine Oil, Trans Oil
- Buy and install a second set of Kosei K1 Racing wheels with Dunlop Direzza ZII tires
