ignition setup page 59
intake pipe for the turbo page 58
finally! page 58
engine is in page 57
its time for a belt whooping! page 56
Skunk2 LMA installed page 55
turbo mock up on the motor page 54
turbo is here page 54
blueprints page 53
turbo needs some work page 51
the tear down page 51
new head page 50
new block (ERL) page 49
is it my clutch? page 44
retuned for moar powa! page 42
slicks and oil catch can page 41
cornfused and transmission is in page 40
transmission toys page 38
oil leak, but no big problem page 37
lower ball joint discussion and completed page 35
sneak peek video page 34
need some wheels and tires page 32
wanting to resleeve page 30
New wastegate page 29
track time page 29
wastegate stuff page 28
update on 14in fan and things i will most likely be doing page 27
mom inspired shift boot page 27
zirgo 14in fan installed! page 26
the first week page 25
dyno graph page 24
omg $$ page 23
to much heat page 23
replacing fan.... page 22
exhaust done, feed line leak on turbo side page 21
the latest and greatest! page 20
car starts up! page 20
almost there page 19
ol return drama page 18
turbo kit is on...mostly page 17
suspension parts page 17
sorry for the wait page 16
exhaust leak fixed! page 16
NA dyno tune before turbo page 15
it never ends!!! page 15
s300 installed page 15
cake pan fan shroud..thanks melt man! page 14
side project page 14
fixed! page 14
replaced starter...still nothing page 14
cap and rotor failure but why page 13
comparing to different turbos with the neighbor page 13
the kit has come! page 12
310+ miles on 1 tank page 11
500 mile oil change page 11
pics and a throw back page 11
success!!! page 10
heartaches page 10
"the oil leak!" page 10
issue found... page 10
back to work page 10
taking a break page 9
engine starts!! forgot to plug in the ecu lol page 9
no engine start up =( page 8
going to start up the engine page 8
engine is installed!!! page 8
rack and pinon mod (thanks meltman!) page 8
engine bay painted page 8
before paint and major update kind of page 7
major update page 7
pistons out! page 6
pulling the engine out page 5
turbo setup page 3
pistons and rods arrive page 2
ive finally started to begin my turbo build on my 95 gsr. im going to do a rebuild on the block but keeping the stock sleeves. this will be a pic and video log (to keep it interesting). ill be posting pictures starting tomorrow on the items i have as of right now.
current my car sits:
i/h/e
s100
ctr cams
165 whp, pulls really nice
wu-chronicle turbo build list:
HAVE:
T3 garret turbo
treadstone exhaust manifold
boost gauge
walbro fuel pump
mistumoto intercooler
tial 38mm wastegate
ACL bearings
golden eagle intake manifold gasket
intercooler pipping
oil pressure gauge
moroso oil pan
Blox 70mm throttle body
cp pistons and eagle rods
NEED:
s300
injectors
down pipe
oil sandwich
oil lines
map sensor
blox air manifold
BOV
Blox/skunk2 Intake manifold
my goals are 300+ hp for starters with this setup. on a later date i may upgrade turbo and of course produce more power. but this car is daily driven along with my second car, i switch back and forth driving them to work. ive done a lot of reading and ive following other build logs that are on this site to get an idea of what to do and not to do. basically ive learned a lot.
if there is anything missing that i missed please feel free to let me know. i do hope i get some followers and make the turbo junkies proud! thanks.
finally! page 58
blueprints page 53
new head page 50
track time page 29
dyno graph page 24
omg $$ page 23
fixed! page 14
success!!! page 10
heartaches page 10
major update page 7
pistons out! page 6
turbo setup page 3
i/h/e
s100
ctr cams
HAVE:
T3 garret turbo
boost gauge
walbro fuel pump
tial 38mm wastegate
ACL bearings
intercooler pipping
oil pressure gauge
moroso oil pan
NEED:
s300
injectors
down pipe
oil sandwich
oil lines
map sensor
blox air manifold
BOV
