#1709 (permalink) |
Real Name: Matt
Model: JDM front GSR
Year: 1995
Feedback Score: 27 reviews
Mystery leak solved! Reason? The casing was not the original case for that tranny so I literally used a bottle of honda bond on it to seal it up, gonna let it dry for a bit then throw it back in and hope that solves it, if not I may just weld the damn thing shut or jbweld it either way I now know the reason and everything has been replaced cleaned and tightened on the outside of the tranny
add me on MySpace CAPTAIN HONDABOND SAYS: when leaks are causing you stress, just hondabond that mess!
| Sponsored Links | |||
Advertisement | |||
#1710 (permalink) |
Real Name: Josh
Model: JDM Teggeh
Year: 99
dont be dumb matt, you know welding it closed is a terrible idea, youre better off with a small leak than you are with it welded closed, if you mess up a syncro or end up w a grind the whole case is trash
JDM from the womb to the tomb echelonwarrior: i love how you just go down the highway at 100 sticking out of the sunroof shirtless Every time matt works on my car he hands me a few bolts and tells me "here, you didnt need these" and sometimes his clutch foot doesnt work properly Mutt's Log |
#1713 (permalink) |
Real Name: John
Model: Supercharged LS
Year: 98
Feedback Score: 22 reviews
Hahah last post was awesome display of fail matt. Dont weld it unless you have access to a torch to cut it back open. Plus, any welder worth with a brain wouldn't do that.
But good thing you got the leak fixed. Please say you didn't use sooo much rtv that the majority of it ended up inside the trans. Although I guess that wouldn't be the worst thing when you compare it o welding the two halves together hah |
#1714 (permalink) |
Real Name: Matt
Year: 1995
Okay let me clear this up lol the welding was a thing you say when your frustrated and was more of a joke haha and as far as the rtv goes captain hondabond gotta make sure it's sealed up so as far as how much I'll say this, it's sealed so I used just enough
#1720 (permalink) |
Real Name: Matt
Year: 1995
Someone explain how the stock super flimsy as hell mounts do any good what so ever... I have solid Mounts the motor has zero flex at all so bolting on trq mounts is just adding more rubber and pretty much useless why add more "stiffness" if you even want to call it stiff to something that has zero flex whatsoever...
#1721 (permalink) |
Real Name: Matt
Year: 1995
Oh goody I've discovered a leak in the brake system, master cylinder is empty. Now I'm sure it's something to do with my abs delete now for the fun part of chasing each line till I find the leak -_-
#1722 (permalink) |
Real Name: Dan
Model: Integra LS
Year: 96
Install air brake mod? Lol
Dan - 94 GSR w/ LS-T (300whp/297wftlbs) - 96 Integra (TOTALED) - 91 MR2 Turbo (SOLD) - 91 MR2 n/a (SOLD) |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
