Hey I am having troubles with my integra it won't go into gear, I've tried bleeding the clutch and replacing slave and master cylinders, and that didn't work. but the clutch will start the car then go completely soft any ideas?
the clutch allowing the starting the car is an *electrical* thing, not a mechanical thing (the plunger at the top of the pedal is part of the circuit allowing 12 volts to go from key to starter solenoid)
sounds like you have something potentially bad inside the transmission... what is age and milage of your car?
