To those who had S2K CMC replacement - Team Integra Forums - Team Integra
 2Likes
  • 1 Post By drmix
  • 1 Post By Jeffaome
post #1 of 6 (permalink) Old 10-19-2016, 08:54 PM Thread Starter
Articles: 11
What is the best way to replace the hardline from the CMC to the firewall?
The S2K CMC is connecting at the right side, versus the OEM which connected from the top...
It was quite difficult to disconnect the OEM hardline to begin with, even if i bent my own line, it'd be hard to fit it back to the stock location...
Any of your expert input would be appreciated. Thanks!
codenamezero is offline
post #2 of 6 (permalink) Old 10-19-2016, 10:00 PM
drmix's Avatar
I would contact Josh @luck4rmkc at Finishing Lines. Im sure he can make a line for you to go straight from the CMC to the slave cylinder.
Clutch line for EG/DC/EK with B/D/H Series - Finishing Lines
luck4rmkc likes this.
drmix is offline
post #3 of 6 (permalink) Old 10-21-2016, 01:11 AM
Silvia's Avatar
Like stated above. I'm using tuck clutch line all the way to the slave. You got the adapter plate as well?
Silvia is offline
post #4 of 6 (permalink) Old 10-22-2016, 06:44 AM
Jeffaome's Avatar
I'm using the braided line from Finishing Lines. The new CMC is nice, made the clutch pedal just a little heavier which is my personal preference. I've used an 'ebay' braided clutch line and had it split in the middle of a weekend trip so weight your options when buying.
Jeffaome is offline
post #5 of 6 (permalink) Old 10-25-2016, 04:09 PM
luck4rmkc's Avatar
Thanks guys for the referrals! I was able to work with the OP to get him taken care of!
968whp GSR build thread
How to Install an LSD
Brotato Racing - Best E.T. 9.73 @ 151mph
www.finishing-lines.com
luck4rmkc is offline
post #6 of 6 (permalink) Old 05-11-2017, 07:33 PM Thread Starter
Articles: 11
Guys, I have the CMC and the spacer, but I barely got any thread inside. Is it normal? I can thread it maybe 2-5mm.
