LS to GS-R with new life - MalTeg's Running Log - Page 3 - Team Integra Forums - Team Integra
 9Likes
post #29 of 43 (permalink) Old 08-27-2014, 05:42 PM Thread Starter
MalTeg's Avatar
Originally Posted by integra-evan View Post
Haha. Well, the screws from the bottom on the DB are outside the mounting space of the speakers....if that makes sense lol.
oh I know my wife has a DB, but 2 of those screws would line up perfectly with where that metal bar is... lol
Our cars are what the world sees as we are out. Do you want to leave a good impression? Or would you rather just be another person?
If someone helps you, give them a LIKE
I am MalTeg
My build thread is here.
MalTeg is offline
post #30 of 43 (permalink) Old 08-27-2014, 05:48 PM
Feedback Score: 16 reviews
There's a metal bar in your cargo cover? That's weird, the cover in my 95 2 door doesn't have any metal in it.
1999 Adriatic Blue Pearl DB8
1995 Frost White DC4 SE - 2006-2014
1990 Rio Red DA9 RS - 2002-2006
integra-evan is offline
post #31 of 43 (permalink) Old 08-28-2014, 02:38 AM Thread Starter
MalTeg's Avatar
yeah it has 2 metal bars.
MalTeg is offline
post #32 of 43 (permalink) Old 08-28-2014, 10:23 AM
dpaton's Avatar
The 2 doors have a removable pressed fiber 'cargo cover'. It's kinda flimsy.
The 4drs have a package tray, that's part of the unibody. There's actual structure that runs at the top of the trunk inside the rear window. Like on any other car that's not a hatchback.
My FS thread
dpaton is offline
post #33 of 43 (permalink) Old 08-28-2014, 11:18 AM
Weird. Lol.
post #34 of 43 (permalink) Old 08-30-2014, 09:26 AM Thread Starter
MalTeg's Avatar
yeah, that's why I plan on molding carbon fiber to it. Just got sick of bad audio, lol.
dpaton likes this.
MalTeg is offline
post #35 of 43 (permalink) Old 09-28-2014, 12:45 AM Thread Starter
MalTeg's Avatar
Ok, so I FINALLY got around to replacing my flywheel. As some of you know, I bought an XTD Aluminum flywheel before, and have now replaced it with an XACT Streetlite Chromoly flywheel. The XTD looked like it was composed of 3 pieces: a backplate that went towards the engine, a gear plate, and a contact plate. All of my problems came from the gear plate, which during assembly was put on backwards. Basically, the grooves that make your starter teeth line up with the flywheel were on the engine side of the flywheel, so instead of starting my car, the starter would just hit the flywheel incorrectly and just continue spinning. So, the moral here is don't buy XTD... well, more importantly, if you buy a multipiece flywheel, make sure that the gear plate isn't backwards... Wish I had known to look for that before. Would have saved me a lot of trouble...
MalTeg is offline
post #36 of 43 (permalink) Old 10-06-2014, 07:53 PM Thread Starter
MalTeg's Avatar
Only have a small update with no pics for you today. I have found out that my rear motor mount is trash. It started making like a knock sound whenever I would accelerate or hit the brakes. I was able to narrow it down to this courtesy of this wonderful site. I looked at it and sure enough it is trashed. Time to replace.
MalTeg is offline
post #37 of 43 (permalink) Old 03-15-2015, 01:58 AM Thread Starter
MalTeg's Avatar
Haven't posted on here in FOREVER! Decided to do an update: I replaced my carpet with a nice dark grey one courtesy of a donor car, got my dash all sorted out with new vents, went back to OEM GS-R cluster, got an ITR shift boot and some CF vinyl for the surrounding plate, had 2 of my lugnut bolts break when I went to remove the wheel (guy over torqued them) so had the JOY of replacing those which I broke the wheel bearing when I pulled the hub so got to replace that too, finally got actual black door handles, rebuilt my center console with an ACTUAL black one, not just my previously painted ones, also happened to discover a way to get an actual black dash without a swap or paint. You use leather dye, it actually sticks! I was amazed to learn this, and only thought of it by chance (I bought some for my shoes because they were starting to look like crap, then I looked at my dash and felt the same way, so I gave it a try in a small unnoticeable area, and it worked so well I did my whole dash). The one I used was Kiwi Scuff repair.
drmix likes this.
MalTeg is offline
post #38 of 43 (permalink) Old 10-10-2016, 01:30 PM Thread Starter
MalTeg's Avatar
UPDATE: my Integra is down for the count for the moment. I was driving and suddenly lost compression in cylinder 3. When I got home I noticed that there was like a ticking sound. Rent compression tests and realized that there was no compression in it plus when I pulled out the spark plug it was covered in oil. Fuel injection was working perfectly so I decided to leave that alone. Spark plugs were still sparking I still decided to get a new set for once this rebuild is complete. I ripped apart the engine pulled out the Pistons cleaned off all the carbon from them replace the piston rings and reseated of them in their cylinders. I sent the head in for cleaning with a new set of valves to be installed. And I cleaned all the carbon out from the inside of the GSR intake manifold also deleting the butterfly while I was at it. Just waiting on the head to come back from the shop which should be within the next couple of days, and then I will be able to reset that and fire it up and hope.
MalTeg is offline
post #39 of 43 (permalink) Old 10-12-2016, 11:01 PM Thread Starter
MalTeg's Avatar
Well the teg is all back together, but it's not firing. Guess I get to troubleshoot on Friday. Lol
MalTeg is offline
post #40 of 43 (permalink) Old 10-16-2016, 12:28 PM Thread Starter
MalTeg's Avatar
alright, here is my update with pictures. I knew that when i put this engine in my car I would come to regret not rebuilding the head, and sure enough a valve broke (exhibit B). I had a buddy helping me with this rebuild, and I trusted him to do things correctly... That was a poor decision. He didn't use a torque wrench when he was putting in the head bolts (I wasn't home for that part, he just assured me he did it correctly). When I went to start the car, I messed up the brand new head gasket I just bought (although, he technically did when he installed it incorrectly.), so I just ordered a brand new cometic one. I will install it CORRECTLY when it comes in the mail, and hope all is well then. *fingers crossed*
ID:	70281   Click image for larger version
MalTeg is offline
post #41 of 43 (permalink) Old 10-25-2016, 11:14 AM Thread Starter
MalTeg's Avatar
teg is still down... I'm really beating my head on the wall here. I got everything back together and it still wont work. Compression tester is reading really low in all cylinders, but the lowest reading is in cylinder 1 at a whopping 30. The rest are 70/90/160. Since I just rebuilt, the readings should be near 230, but they are not even close and im not sure what to do. When I got it to start, it would run for a couple of minutes and then die. I am going to tear back down to the head bolts and see if maybe I didn't torque them all the way down... idk what else to do at this point... if it isn't fixed soon, I have to give up. Winter is coming and I need to have a running vehicle.
MalTeg is offline
post #42 of 43 (permalink) Old 11-09-2016, 01:34 AM
So close
hope you haven't given up. you've put in a lot already, time and money. I'm watching this post . good-luck!
justcamping is offline
