DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR - Team Integra Forums - Team Integra
Old 08-22-2011, 10:08 PM   #1 (permalink)
LightningTeg's Avatar
Feedback Score: 24 reviews
Default DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR
Doing some highway pulls in my 500whp car and having the brakes fade with race compound pads was unnerving. I decided it was time to upgrade the front brakes. After looking into the idea for months, I stumbled across a combination of ideas. Type R caliper remans can be had for dirt cheap <$30. This is nothing new.The problem was always finding rotors that would work or needed to be drilled and machining the caliper bracket to clear. I felt, along with my colleagues there had to be a rotor that would fit the bill somewhere.
I found a thread on Honda tech where someone had used a Mini Cooper rotor and it bolted up no problem. The hub bore was exactly the same as our Hondas and the 11” diameter fits the bill for the caliper. I bit the bullet I guess you could say and ordered Calipers, Rotors, Pads, and Stainless lines.
I was super happy when the ONLY modification needed was trimming of the dust shield to clear the bigger caliper. No machining of the bracket is neccesary to center the pad either. These combined with EBC reds just destroy my tires at threshold braking which I don’t remember being able to do even auto crossing.
I have not tried other wheels but I have been told LS meshes clear and 15”x6.5 Rota slips do not. Please chime in if you have experience. My 16” GT3’s are very close.
Basic Parts List: (Rock Auto.com)
Centric Type R Brake Caliper Remans - $ 31.79 each
Brackets COME WITH CALIPERS
Centric Premium Mini Cooper rotors 4x100, 280mm diameter - $ 40.79 Each
Total: $145.16 + shipping + your choice of pads
Originally Posted by JRutski View Post
I have to agree- not pretty...and looking back, I'm pretty rusty (hahahaha) being that this is the most welding I've done in some 6-7 years. But hey - function > form
Indeed!! This has got to be the easiest, most straight-forward big-brake upgrade, ever. And with OEM parts to boot! Here's everything mounted - it just looks plain good:
I was honestly a bit worried about the bolt holes - I think they're 1 or 2 mm larger on the Coop rotors than the Integra's - but then I remembered that the center diameter is exactly the same, so no worries.
Here's the hardest modification you'll need to make - you can see here that the Type-R calipers are clearly larger and interfere with the dust shield:
Just break out the old angle grinder and cut here:
And here you can see fitment is good after the two cuts:
Still need to order the pads and the SS lines...but it's certainly coming along.
DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR-brakedone.jpg   DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR-brakeshielddone.jpg   DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR-brakeshieldint.jpg   DIY: The No BS Bolt on Big brakes for RS/GS/LS/GSR-dustshieldcuts.jpg
97' Civic EX LS swapped DD
98' Integra LS Previously 283whp/300ft-lbs; PB 12.88 @ 112; Now 500whp+ 20lbs 93 oct.
LightningTeg is offline   Reply With Quote
Old 08-22-2011, 10:15 PM   #2 (permalink)
Hmmmm, may have to try those with my nsx calipers. Make the swap even easier and just toss the heat sheild instead of trimming it.
On any given raceday, more mazdas get in the way of hondas than any other car out there. [URL=http://racing.honda.com/hpd/] Honda Performance Division Prima Racing; Little guys doin' big things "You never press the gas pedal until you know you never have to take it off." --Jackie Stewart"
RacerZook is offline   Reply With Quote
Old 08-22-2011, 10:24 PM   #3 (permalink)
stillhere153's Avatar
Feedback Score: 22 reviews
Mmmh that's Def a good way to get it done
stillhere153 is offline   Reply With Quote
Old 08-22-2011, 10:51 PM   #4 (permalink)
Articles: 11
Nice, i'm going to grind those stupid dust shield lol never thought about it (since i hate to cut anything OEM hehe...) But i thought you need to get the bracket from fastbrakes to line it up? Otherwise you will get uneven wear? Could be wrong. I had to get a bracket for my NASX calipers.
codenamezero is offline   Reply With Quote
Old 08-22-2011, 10:52 PM   #5 (permalink)
Real Name: Casey
Model: Turbo GSR
Year: 2000
Feedback Score: 35 reviews
I approve this upgrade.
MeltMan is offline   Reply With Quote
Old 08-22-2011, 10:54 PM   #6 (permalink)
Real Name: Esteban
Model: GS
Year: 1999
bookmarked!
Esteban8657 is online now   Reply With Quote
Old 08-22-2011, 10:58 PM   #7 (permalink)
ThatGuy's Avatar
Real Name: Dane
Model: SE
Year: 2000
I've been waiting a long time for someone to figure this out lol Koodos.
Just to be clear, do you know the model/year of the mini cooper that these are from? the 2010 Mini Cooper S perhaps?
95 Auto LS - Lost in a race, got mad and sold it.
95 JDM Front B20 - Someone hit me, parted out
00 RS - Dragon Slayer
(ThatGuy,P24martin) The first 2 from a different country to ever do the TI Dragon Run!
The Only Canadian to ever to do the Dragon 4 consecutive years.
ThatGuy is offline   Reply With Quote
Old 08-22-2011, 11:00 PM   #8 (permalink)
2007 Mini cooper, non S. Just check the diameter
Old 08-22-2011, 11:01 PM   #9 (permalink)
Real Name: Tim
Model: 96 Integra SE Sedan
Year: 1996
Awesome thread. I may sound like a newb but whats the difference in the LS,GS,RS,GSR calipers to Type R?
96GreenDB is offline   Reply With Quote
Old 08-22-2011, 11:14 PM   #10 (permalink)
Got a part# for us?
Old 08-23-2011, 12:02 AM   #11 (permalink)
Feedback Score: 13 reviews
Know if it applies to rear brakes as well?
Meltman:We here at TI all appreciate you trashing a perfectly good ITR engine because you're dumb.
Forced induction is NOT a fix for bad VE
B18Ch1ck: I am making noodles,they probably handle better than a DC5
SniperX is offline   Reply With Quote
Old 08-23-2011, 12:57 AM   #12 (permalink)
You know Id be damned, the rear type R brakes are 10.25" and the rear mini brakes are 10.23". So yeah, it would probably work.
Problem is the rear calipers are not so common and are $100 a pop without cores.
Old 08-23-2011, 12:58 AM   #13 (permalink)
Pad is bigger and rotor is 11" in diameter vs 10.3".
Old 08-23-2011, 01:27 AM   #14 (permalink)
I read somewhere that you can use rear 2002-2003 civic si rotors and si/rsx rear calipers or vigor rear calipers (not sure). I think you just have to swap the right to the left and flip the caliper. Only thing is your bleeder will be upside down.
2000vsmGS is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
