Looking to change valve cover gasket - Team Integra Forums - Team Integra
post #1 of 14 (permalink) Old 09-07-2010, 12:57 AM Thread Starter
Pocky_Miester's Avatar
Hey T.I.
I got a few seeps in my gasket and I am going to order a valve cover gasket set. I wanted to asked before I ordered but has anyone used aftermarket companies for gaskets. I am looking at a company called Stone here. I would feel better with oem but I figured it would be expensive compared to this. What are your experiences?
Thanks,
Luke
Pocky_Miester is offline
post #2 of 14 (permalink) Old 09-07-2010, 01:07 AM
echelonwarrior's Avatar
Feedback Score: 27 reviews
fel-pro is crap the gasket itself is fine but when u flip it over to put in on the gasket likes to fall out. ive reused my oem gasket like 20 times best thing ive found is to just lay a thin layer of honda bond all the way around the lip of the head then pull the gasket on that itll seal it up nice.
add me on MySpace CAPTAIN HONDABOND SAYS: when leaks are causing you stress, just hondabond that mess!
echelonwarrior is offline
post #3 of 14 (permalink) Old 09-07-2010, 01:55 AM
or a real thin coat of black rtv, that's what i do every time i re use my shit lol
sugarfree135 is offline
post #4 of 14 (permalink) Old 09-07-2010, 02:02 AM
nice to know you guys are re using yours w/ no problems. I've wanted to install my other VC but been to lazy and cheap to buy a gasket. I've re used one before but it was only like a month old or less.
Anyone know the size of the hose that goes to the breather I believe is what it's called. Mines stuck and I just want to cut it off and buy a new one. Thanks
A97B18B is offline
post #5 of 14 (permalink) Old 09-07-2010, 02:17 AM
Feedback Score: 37 reviews
^I believe it's 3/8.
- 1996 Integra SE 598WHP 33 PSI 101 Octane - RedZoneRace tuned
- 1994 Civic VX 342WHP 15 PSI 91 Octane - W1ckedOne/DNR tuned
- 2006 Tacoma TRD Sport ???WHP 8 PSI TRD Supercharged
DC4KiD is offline
post #6 of 14 (permalink) Old 09-07-2010, 08:03 AM Thread Starter
yeah I was thinking that was the case I will go with oem so I don't worry and it will last longer.
post #7 of 14 (permalink) Old 09-07-2010, 11:51 AM
...we are talking $9 for a new valve cover gasket.
thomapa1 is offline
post #8 of 14 (permalink) Old 09-07-2010, 11:55 AM
Articles: 8
Feedback Score: 33 reviews
OEM one fits perfectly, lasts a long time, and is readily available.
TheGSRGuy is offline
post #9 of 14 (permalink) Old 09-08-2010, 01:28 AM
pay a few bucks more for OEM....you'll be glad you did!
used a generic valve cover and it seeped after 10k miles. Oem has been perfect thus far.
Main thing is to Torque them down in the correct sequence and do it in increments i.e. 3ft, 5ft and finally at 7-8ft pounds
20LS01 is offline
post #10 of 14 (permalink) Old 09-13-2010, 05:36 PM Thread Starter
I don't think the valve cover gasket SET is that cheap.
post #11 of 14 (permalink) Old 09-13-2010, 05:40 PM
Banned
Feedback Score: 22 reviews
Just get OEM.
It's not that expensive...
arexniba is offline
post #12 of 14 (permalink) Old 09-20-2010, 03:34 AM
I noticed a lot of people are saying they re-use their gaskets. While most of us are known for doing repairs the "Old fashioned" way I would like to just point out that the proper repair and maint. on valve cover gasket replacement is when ever you take the valve cover off you are suppose to replace the gasket every time. Just FYI.
TakashiDrift is offline
post #13 of 14 (permalink) Old 09-20-2010, 06:51 AM
hondaguy92's Avatar
ive used fel-pro with no problems whatsoever, just used sealant around the head and under the v.c and you're fine, it doesn't "like" to fall out once it's seated correctly. Mine had to be replaced but they can be re-used if you're gentle
hondaguy92 is offline
post #14 of 14 (permalink) Old 09-20-2010, 09:12 AM
I just looked up the oem price for you, its like $9.00.
drkvltprls is offline
