Resistor box plug and play DIY - Team Integra Forums - Team Integra
Old 04-16-2010, 11:23 PM   #1 (permalink)
Real Name: Casey
Model: The 'L' train
Feedback Score: 35 reviews
Here's a little writeup to make a true plug and play resistor box for your teg.
Need:
OBD1 distributor side plug (4x2 pin rows) OR Ac subharness (front passenger by the radiator) plug from a teg
Prelude resistor pack
Soldering iron
First off, here's the Prelude OBD1 resistor box with plug: (plug from prelude DOES NOT plug right in a teg)
Here's the dead plug (with the dead plug removed:
And here's what we're wiring up:
So depin the prelude harness and your matching 8 pin oem plug (Sourced from OBD1 dizzy or AC sub harness)
I colored orange and white wires red to match the one red wire in the prelude box. Here's how I staggered the extra +12 wires before soldering:
Those joints were soldered! You MUST do this step, not optional! I then placed heat shrink over the whole bundle:
And repinned the harness plug:
And here's the final plug and play product:
MeltMan is offline   Reply With Quote
Old 04-16-2010, 11:35 PM   #2 (permalink)
Real Name: Robb
Model: GSR
Year: 2000
1) These are sneaky
2) Nice wiring job. Very clean.
3) Tots doing this...
I like learning. Don't you? My JRSC build log
BlownGsR1001 is offline   Reply With Quote
Old 04-17-2010, 12:00 AM   #3 (permalink)
Banned
Real Name: Chandler
Model: STi
Year: 2005
As always Casey, Good work! Your projects always come out so clean.
97lsteggy is offline   Reply With Quote
Old 04-17-2010, 12:29 AM   #4 (permalink)
luck4rmkc's Avatar
Real Name: Josh
Model: Turbo GSR
Year: '97
Looks good casey I have high impedance injectors so i didn't need to do this myself. What kind of advantages do you see from the ball and seat injectors as opposed to the saturated?
600whp GSR build thread
How to Install an LSD
FS clutch tuck lines
Brotato Racing - Best E.T. 11.43 @ 130mph
luck4rmkc is offline   Reply With Quote
Old 04-17-2010, 02:44 AM   #5 (permalink)
Banned
What is the exact purpose of this? Why would you need to add resistors to your fuel injectors? -Aaron
theivjackal is offline   Reply With Quote
Old 04-17-2010, 02:54 AM   #6 (permalink)
sgtmillhouse648's Avatar
Real Name: Malhon
Model: Trailblazer LT
Year: 2002
When using low impedence injectors for higher hp builds, it is necessary to beef up the resistance of the injector circuit otherwise you will fry the injector drivers.
1984 Red Devil VF750F Interceptor Swap
2002 Chevy Trailblazer LT
"One of the great things in motor racing is concentration. When I want to go faster I don't drive any faster, I just concentrate harder." - Jim Clark
sgtmillhouse648 is offline   Reply With Quote
Old 04-17-2010, 10:46 AM   #7 (permalink)
Real Name: Casey
$MoNEY$
I'm using Evo 8 injectors. They were $100 for 560cc and are modern OEM with a good spray pattern.
Old 04-17-2010, 11:37 AM   #8 (permalink)
Nice write up.
"SAVE A TREE EAT A BEAVER"
ONE4ONE is offline   Reply With Quote
Old 04-17-2010, 11:49 AM   #9 (permalink)
luck4rmkc's Avatar
Real Name: Josh
Model: Turbo GSR
Year: '97
Originally Posted by MeltMan on Apr/17/10
Quote: luck4rmkc on Apr/16/10Looks good casey I have high impedance injectors so i didn't need to do this myself. What kind of advantages do you see from the ball and seat injectors as opposed to the saturated?
$MoNEY$
ok I feel that... well my wallet feels that cuz it is emptyyyyyyy!!!!! I was thinking I remembered that the ball and seat style injectors were better in some way. Like they had a better spray pattern or were more accurate when tuning but i couldn't remember
Old 04-17-2010, 08:50 PM   #10 (permalink)
Real Name: Casey
Here's where I put it. Dont know what that threaded hole was for but it works perfectly for the resistor box.
Old 04-17-2010, 10:12 PM   #11 (permalink)
Ramirez428's Avatar
Real Name: Jose
Model: GSR
Year: 1995
Good job there Casey. Keeping it plug-n-play as always
Ramirez428 is offline   Reply With Quote
Old 04-19-2010, 03:12 PM   #12 (permalink)
JRutski's Avatar
Dangit!!!! Now I have another weeked project!
Nice, as always Casey!
If Acura ever decides to go searching for its soul, it's out in my garage.
JRutski is offline   Reply With Quote
Old 04-26-2010, 11:48 PM   #13 (permalink)
will be doing this as well! i will post pics of it when its finished =)
PB in my built beast gsr: 10.8 @ 129mph pump gas 19lbs 450whp
PB in my stock long block boosted LS: 12.2 @ 113mph 17lbs 307whp/283tq
Antman985 is offline   Reply With Quote
Old 07-31-2010, 12:57 AM   #14 (permalink)
hey where did you get the pins and the the little rubber grommets for the pins?
thanks
Project SOHC Project Wagon!
sohc-it07 is offline   Reply With Quote
