Have a victorx manifold with four additional injectors on the bottom, I don't use them and do not want to leave them sitting in there.. So I was wondering if any of you could help me figure out some way in blocking up the holes, Should I try and fill them with aluminum epoxy or find some kind of rubber plug and shove it in there? not sure what to do.
Use an expanding metal plug, or any other plug designed for that kind of purpose. Lowes sells something of that type. I used one to plug My IAT sensor hole, still holding up! Just make sure it will be able to handle the 14lbs of vacum, you dont want anything like that, or pieces of it, ending up in your cylinders...
Edit:also remember that thing can get frigin hot too, so plastic/rubber might not be the best solution
That's a good idea, i'll see what i can find.. thank's for the input
