Melt's 5-spd Swap log: complete - Page 22 - Team Integra Forums - Team Integra
post #295 of 301 (permalink) Old 09-17-2013, 07:34 PM
Hey I have a question about the syncros your using. Has there been a incease/decrease in transmission braking. How about noise. Is it different sounding, louder, etc. Thanks.
5thOwnerDB8 is offline
post #296 of 301 (permalink) Old 08-03-2015, 01:02 AM
Hey melt what clutch is in the car now? Still the stage one? Cause the paper with the write out of mods says it's a stage four. I don't know if it was you that made up this folder of paper work or if somebody else typed out the mod list and lied about the clutch. My friend asked what I had in it since he's about to get a new one. Thought I would turn to you like it seems like a lot of people do haha.
because there aint no rest for the wicked, untell we close our eyes for good.
Neeland is offline
post #297 of 301 (permalink) Old 12-20-2015, 11:06 PM
Bg33pDc's Avatar
Awesome write up!!!
Bg33pDc is offline
post #298 of 301 (permalink) Old 02-15-2016, 03:38 AM
Don't mean to bring this thread back from the dead, but Meltman you are the S*** i've just finished my 94 auto to 5 speed, ls to gsr swap, and your whole thread has been very helpful and got everything i needed to work. Thanks again!
greenjellybean98 is offline
post #299 of 301 (permalink) Old 03-01-2017, 08:07 AM
Originally Posted by MeltMan View Post
well, the dogteeth gears were mashed flat from the previous owner grinding the hell out of reverse. Reverse isnt a high tolerance gear. I just wanted to make sure it would go in nicely instead of butting against a flattened gear. I just reshaped the flat spots to be points.
From what I cant tell it had definite benefit as reverse goes in like buttah.
Hey MeltMan, I finally got around to getting a used 94 LS trans. Everything looks pretty good inside the case except the reverse gears. I took apart mainly because I did not know its history and wanted to check it over and replace the common ISB before I had to yank it out too soon. I read that you reshaped your reverse gears. Could you comment on mine if I can maybe reshape or do I need to replace? Im trying to be on a budget. If it was a GSR trans I would be all for replacing, but not sure how long I will have this trans. Thanks in advance. Mac
Water leaks fixed for now. Working on getting body back to OEM.
macura2001 is offline
post #300 of 301 (permalink) Old 03-04-2017, 09:25 AM Thread Starter
I just took a dremel and made the pointy edges of each gear "pointy" again.
Mine looked much like that. It just makes it easier to get into reverse.
post #301 of 301 (permalink) Old 03-07-2017, 10:09 PM
Thanks, it look as I may be doing that myself. I was going to buy a revese idler gear for LS trans and it is discontinued by Honda. Best I can do is buy a 1/2 sleeve from gearspeed that has external gear and dremel the idler gear. I think I will save some money and dremel both. Thanks again.
