Asr sway bar and brace question - Team Integra Forums - Team Integra
Old 07-14-2012, 07:51 PM   #1 (permalink)
carbondc2's Avatar
Real Name: erik
Model: gsr jdm front
Year: 96
Feedback Score: 23 reviews
Default Asr sway bar and brace question
I have a asr swaybar and subframe brace setup on my integra and the bushings that come with the kit keep becoming loose and falling out of the c clamps that hold them in.maybe it's bc of the screwed up roads here in pa but I was wondering if anybody else had the same issue?
260 whp 0 psi
carbondc2 is online now   Reply With Quote
Old 07-14-2012, 07:59 PM   #2 (permalink)
You mean the sway bar bushings correct? If the problem persists i would entertain the idea of putting stop collars on either end to keep it from happening, maybe with a rubber type washer so it doesnt make noise.
Function > Form / Stance is WACK
Boardorgohome is offline   Reply With Quote
Old 07-14-2012, 08:24 PM   #3 (permalink)
stillhere153's Avatar
Feedback Score: 26 reviews
or replace with prothane bushings
$15
stillhere153 is offline   Reply With Quote
Old 07-14-2012, 09:42 PM   #4 (permalink)
carbondc2's Avatar
Real Name: erik
Year: 96
Maybe the poly bushings are the way to go..thanks man
Old 07-14-2012, 10:28 PM   #5 (permalink)
they work
:toocool:
^ prothane or energy have flares at the end where asr supplied bushings don't
Old 07-14-2012, 10:28 PM   #6 (permalink)
I thought they already had poly bushings...
Old 07-14-2012, 10:38 PM   #7 (permalink)
carbondc2's Avatar
Real Name: erik
Year: 96
I thought so too about them being poly.they do have the flair at the end of them but after about 50-60 miles on them they get shook loose and I'm able to move my sway bar up and down about a inch...I was thinking about epoxying them on the sway bar itself so they would stay put.any ideas about that?
Old 07-14-2012, 10:39 PM   #8 (permalink)
carbondc2's Avatar
Real Name: erik
Year: 96
Originally Posted by stillhere153 View Post
they work
:toocool:
These look like the exact bushings I have
Old 07-14-2012, 10:43 PM   #9 (permalink)
you've got left? which is flare 1 side, prothane and energy flare both sides
bushings on the right
double flared
ps. epoxy won't hold them guarantee first turn pop loose
Old 07-14-2012, 10:44 PM   #10 (permalink)
so they only have that lip on one side? no wonder they work out... i would go with the energy ones if they have a lip on both sides. I think autozone stocks energy stuff, i sorta recall walking into the one in York the other day and seeing some on the shelf.
Old 07-14-2012, 10:59 PM   #11 (permalink)
I believe they are cheaper on amazon/ebay with free ship, and you don't have to hunt down the proper size... asr bar also what is it 24mm? doubt azone stock that big
Old 07-14-2012, 11:06 PM   #12 (permalink)
Just a suggestion to save time, like i said i'm not positive but its worth a try.
Old 07-14-2012, 11:29 PM   #13 (permalink)
carbondc2's Avatar
Real Name: erik
Year: 96
double flared
Now I see.i didn't notice the bushing on c clamp was flared on both sides.I'm going to pick some up
