How do I get the bolt off the top of the rear struts? - Team Integra Forums - Team Integra
Old 02-21-2012, 07:43 PM   #1 (permalink)
Default How do I get the bolt off the top of the rear struts?
Changing the rear struts on a '97 GSR, have the spring compressed and ready to pull the strut out but I can NOT get that bolt that holds the rod off of the top!
When i turn it with a wrench the entire rod turns, i can't find anywhere to put a clamp to hold the damn thing... how do I go about doing this?
Thanks all!
-GSR from hell-
Integraoligist is offline   Reply With Quote
Old 02-21-2012, 07:59 PM   #2 (permalink)
MurderedDA's Avatar
Real Name: Brandon
Model: Integra GS
Year: 1990
hit it with an impact. did mine last weekend.
"If you don't crash or break down every now and then, you're not going fast enough." - John Hennessey
MurderedDA is offline   Reply With Quote
Old 02-21-2012, 08:04 PM   #3 (permalink)
shoul,d be a hex hole on top of the strut rod. use a hex key to hold it in place
366hp/278tq
sheryip is offline   Reply With Quote
Old 02-21-2012, 08:29 PM   #4 (permalink)
MurderedDA's Avatar
Real Name: Brandon
Model: Integra GS
Year: 1990
^^ X2 i forgot i did have to use the hex on one of them sorry
Old 02-21-2012, 08:35 PM   #5 (permalink)
Tried to hold the top with a hex but the nuts rusted on. How do you go about holding an spent wrench on it while using an impact driver?
Old 02-21-2012, 08:46 PM   #6 (permalink)
MurderedDA's Avatar
Real Name: Brandon
Model: Integra GS
Year: 1990
the impact hits hard enough where u don't have to worry about the inside moving usually.. but idk if it will when the bolt is rusted on. its worth a shot, though.
EDIT: put some PB blaster on it so it breaks loose easier.
Old 02-21-2012, 08:59 PM   #7 (permalink)
haichid's Avatar
Real Name: James
Model: RHD GSR
Year: 2001
Send a message via Yahoo to haichid
If your only intention is to save the top hats with no concern of damaging the shock or nut you could use a nut splitter. I found myself in a similar sitution and as a last resort used one.
haichid is offline   Reply With Quote
Old 02-21-2012, 11:39 PM   #8 (permalink)
Just use a grinder? I can't remember exactly how they look but I think thats what I did, either that or I clamped the shaft with a vice between the springs.
Been so long ago...
Mike's Teg - Updated Dec 2012 • 18G Turbo • Rebuilt GSR • Dyno Pending...
migee is offline   Reply With Quote
Old 02-22-2012, 12:31 AM   #9 (permalink)
Soak with pb blaster then try a hex tool/wrench,
95 Milano Red ls - Rip 94 Paradise Blue Green gsr - Sold 95 Taffeta White rs - Current daily driver 01 Berlina black Ap1 - Mountain warrior
ap1-dc4 is offline   Reply With Quote
Old 02-22-2012, 01:37 AM   #10 (permalink)
Model: LS
Feedback Score: 13 reviews
First Uncompress the spring. Hit it with some kind of penetrating oil and let it sit for a few minutes. Next try loosing the nut while using the allen wrench. It should break free. Once you have it loosened pretty good, compress the spring and remove the nut.
blkteg21 is offline   Reply With Quote
Old 02-22-2012, 10:10 AM   #11 (permalink)
I agree with Uncompressing the spring... You'll need all that pressure to break it loose. DO NOT fully remove that nut while the spring is Uncompressed though!
The trick that has worked for me countless times on numerous struts/shocks.... Grab a piece of the stickiest Duck Tape or equivalent you can find (shit has to be strong and sticky though). Tear in about a one inch or so strip and wrap it around the shaft two or three times overlapping. Grab a pair of Vice Grips and clamp them down using every ounce of strength in your being. Allow them to rotate until they wedge themselves tight in the spring as you turn the nut... and if you've done it right.. It WILL hold the shaft from spinning
Trying it with Duck Tape is worth a shot.. I see no reason why a good sticky brand (not the cheap junk) wouldn't hold just fine. This is the stuff I have laying around: http://www.tapemanblue.com/redstuccotape.html
It's outrageously expensive and is every bit twice (if not more) as strong as duck tape
Good Luck
Your muffler bearings fell off. get some blinker fluid and rub it all over your lights, then check the car to see if the flux-capacitor is still there
g3integragsr is offline   Reply With Quote
Old 02-22-2012, 12:21 PM   #12 (permalink)
ok, got the first one off with letting it soak in wd40 all night... before i move on to the next, how do I remove the boot off the stock strut to put on the new one? Looks like it's attached to the strut itself.
Thanks again all for the help!
Old 02-22-2012, 01:00 PM   #13 (permalink)
MurderedDA's Avatar
Real Name: Brandon
Model: Integra GS
Year: 1990
the rubber piece that sits on top of the spring? pry it out with a flat head screwdriver.
if thats not what u were talking about, please specify.
Old 02-22-2012, 02:05 PM   #14 (permalink)
GreyTeg's Avatar
Real Name: Corey
Model: LS
I just cut the shock in half right below the nut. Why would you want to save those shocks anyways?
GreyTeg is offline   Reply With Quote
