LinkBack | Thread Tools |
#1 (permalink) |
Model: Acura Integra GSR
Year: 1999
I tried searching all over the web. I still can't find the answer. I have a subframe like the one shown below (made by R-crew). I wonder if the ASR 24MM sway bar will work on it. So the question really is if the bracket for ASR 24mm Sway Bar will fit on a OEM Type R frame, since I am using a OEM bracket on a ITR sway bar. Also, I remember there were an discussion about how to adjust the rear sway bar with the adjustable endlink. I can't find it anymore. If anyone knows that discussion, can you put up the link.
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Year: 1999
I tried searching online again. I hope some people would have this setup and confirm that this would work. I really don't want to buy the 24mm Sway Bar then it turns out doesn't fit.
#3 (permalink) |
Real Name: Eric
Model: GSR
Year: 96
So long as you get the bar for the ITR, you should be fine. However, have no idea whether or not your current brace can handle the added stress of the 24mm bar.
Sent from my Autoguide iPhone app Last edited by Drache; 02-07-2012 at 07:41 PM. |
#5 (permalink) | |
Year: 1999
I thought the ASR 24MM Sway Bar comes with the D brackets/bushings. I am getting a set of the new Blox endlinks. So, I should be good there. |
#6 (permalink) |
Feedback Score: 22 reviews
the distance from the bolts may be different you may require 24mm energy D brackets instead here's a picture to show why, the energy has more "adjust-ability" since it is universal
#7 (permalink) | |
Real Name: Darrell
Model: LS Coupe
Year: 1995
asr sways comes with the d-brackets and I think the endlinks as well...mine did |
#8 (permalink) |
Real Name: Eric
Model: GSR
Year: 96
I know the end links come with the complete kit (sway bar & brace), but looking at jhpusa.com, they note that the sway bar alone does NOT come with end links.
Sent from my Autoguide iPhone app |
#9 (permalink) | |
Year: 1999
Thanks for all the information BTW. |
#11 (permalink) |
Real Name: albert
Model: 92 civic hb
Year: 92
yes the asr 24mm would bolt up to the r*crew brace
http://www.automationLED.com for all your automotive LED light bulb needs enter coupon code "cheeseburger" to receive FREE SHIPPING in the US on orders over $50, enter coupon code "nwp4life" to receive 10% you're entire order |
#12 (permalink) |
Real Name: Eric
Model: GSR
Year: 96
The larger bar adds stress to anything it's connected to; The LCA's and the subframe mounting points. Search "subframe tear-out" if you want to see pics of the potential damage.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
