Cant take out AXLE nut - Team Integra Forums - Team Integra
post #1 of 15 (permalink) Old 11-07-2011, 11:18 AM Thread Starter
having a hard time taking out the axle nut. Used a lot of PB blaster and wd40 and still not doing the trick. used like 4 breaker bar already and broke all of them. Blowtorched the bolt til it was red and still nothing. Dont have access to a impact gun and cant drive my car to a shop to get it fix so im am out of ideas. Can anybody please give me som tip on how to take this bolt out without using an impact gun. I dont want to break anymore tools.
Johnsport is offline
post #2 of 15 (permalink) Old 11-07-2011, 11:25 AM
Articles: 76
What did you use for breaker bars?
I've used the handle from a floor jack and standing on it pushing down has always worked for me
post #3 of 15 (permalink) Old 11-07-2011, 11:27 AM
blinkz0rz's Avatar
Do you have the right axle nut socket?
blink aka Jrod
'94 DC4 Integra RS
LS/VTEC build
blinkz0rz is offline
post #4 of 15 (permalink) Old 11-07-2011, 11:58 AM
UrbanB's Avatar
i used a 6ft breaker bar and mine were original axles from 95. if mine came off yours certainly should.
you still have the wheel on/on the ground when you're cranking on it, right?
-b
UrbanB is offline
post #5 of 15 (permalink) Old 11-07-2011, 12:13 PM
If you broke 4 breaker bars I believe your doing something wrong. Be sure to punch out the lock on the the rim of the nut...
Sent from my Autoguide iPhone app
-"Uhmm... isn't V8 a juice?" -"Yes indeed it is, it is found under the hood of many cars, next to the Tomato Soup and grape juice."
BGPStunna is offline
post #6 of 15 (permalink) Old 11-07-2011, 12:23 PM
1fastautoteggy's Avatar
i had to drill 2 small holes then crack it open with a punch on my driver side nut. that wasnt fun one damn bit
1fastautoteggy is offline
post #7 of 15 (permalink) Old 11-07-2011, 12:54 PM
LightningTeg's Avatar
Feedback Score: 24 reviews
You shouldnt have to move that tab holding it. Its really ductile metal and the torque of the nut is much greater then the force you would need to get past that. 1/2 breaker bar with the shaft of a floor jack should easily do it.
08' TSX
LightningTeg is offline
post #8 of 15 (permalink) Old 11-07-2011, 02:41 PM
The way I do it, is I leave the car on the ground with the tire and everything, and just pop the center cap out.
Get a friend, put it in gear, pull up he Ebrake (so the back holds the front), stomp on the pedal,
Then I just jump on it with the socket in there. I went to a metal shop in the industrial area and went to their junk bin.
I found a 1/2 inch thick, 2 inch diameter steel pipe that is 4 feet long for 2 dollars, weights almost 20 lbs. Thats my breaker bar
Why is the word Integra underlined with red as a spelling mistake? =O ?
ZeGege is offline
post #9 of 15 (permalink) Old 11-08-2011, 04:19 PM
20LS01 is offline
post #10 of 15 (permalink) Old 11-08-2011, 04:55 PM
Not necessarily. I've had one that was rusted up so bad we broke 3 breaker bars and 2 1/2" drive wrenches.
We had to buy a 3/4 drive bar. That finally won.
post #11 of 15 (permalink) Old 11-08-2011, 06:39 PM
Buy a quality breaker bar and try it again. A heat gun would also help.
YeahYeahYeah1 is offline
post #12 of 15 (permalink) Old 11-08-2011, 08:39 PM
i just removed front rotors on my dads 94 accord and had to remove the axle nut.....some pb blaster and a dewalt 325 ft/lbs forward/reverse impact gun did the trick....def took as many hits with the gun as did my crank bolt on my teg lol.
integrajerzey is offline
post #13 of 15 (permalink) Old 11-08-2011, 09:11 PM
GreyTeg's Avatar
Axle nut > 1/2 drive. This happened to me first hand as well.
GreyTeg is offline
post #14 of 15 (permalink) Old 12-03-2011, 01:09 PM
I broke a breaker bar on that nut, one of those 3 foot things that are intended specifically for the purpose. Then got a stronger one and put a 6-foot THICK pipe on it. The main problem was the socket slipping off the axle nut. Eventually it gave though. You are using weak pipes / breaker bars.
Also, don't jerk them, apply consistent force if you aren't already.
avraell is offline
