ek da eg uca fit? - Team Integra Forums - Team Integra
post #1 of 8 (permalink) Old 02-26-2008, 04:40 PM Thread Starter
i just want it to know if a stock uca from a ek da and eg will fit on a dc because i need some bad but cant find one for the dc. thanx
JDMspoonDC2b18C is offline
post #2 of 8 (permalink) Old 02-26-2008, 04:48 PM
they have some dc ones on ebay I got one for 50 shipped brand new with ball joint, bushings, etc., and has a warranty on it i believe
EDIT: 2 on this page for $43
boridragon02 is offline
post #3 of 8 (permalink) Old 02-26-2008, 05:06 PM Thread Starter
i need the whole arm...
post #4 of 8 (permalink) Old 02-26-2008, 05:11 PM
Um...that looks like the whole front upper control arm to me and so does the one I have sitting in my room, what would you be missing?
post #5 of 8 (permalink) Old 02-26-2008, 05:16 PM
You asked for an Upper Control Arm, boridragon02 gave u links to them.
As far as suspension, its interchangable between 92-95 civics. Not 100% sure if its all suspension parts or not.
supersilverteg is offline
post #6 of 8 (permalink) Old 03-29-2008, 11:02 AM
ALL eg civic suspension parts are swappable with dc's
save two problem children:
1. type r rear lca's. different than all civics and tegs, require different shock to make it work.
2. SOME civic front lca. if the donor civic is dx or some other low end marque, check to insure that the front lcas have sway bar mounting holes. the ones that do usually have a dinky sway bar in there but i know from experience that the dx coupes came with zero sway bars. no sway bars = no mounting points.
bacardiboi03 is offline
post #7 of 8 (permalink) Old 04-08-2008, 12:35 AM
DA front (I assume you mean front) upper control arms are different than EF upper control arms, and both are different than EG/DC upper control arms (which are identical)
It just so happens EF upper control arms will fit a DA with a little tweaking and give you a bit of camber...but I digress
ASE certified Master Auto Tech. Going for my Mechanical Engineering degree!! 1990 Integra GS (two!) 1992 Ford Ranger Turbo
pressingonward is offline
post #8 of 8 (permalink) Old 04-08-2008, 12:50 AM
Nunez's Avatar
i got some of my parts from a 94 civic if it helps in anyway.
Nunez is offline
