in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Technical / Help
Suspension and Brakes
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 283
Go to page
Go
283
R
94 b18 with 98 itr trans, what axle needed
RTC1 teggy
Dec 11, 2023
1
275
Dec 17, 2023
by
RTC1 teggy
D
ABS Code 1-8 (high pressure system) on 97 integra LS
djraymond
Nov 20, 2023
2
341
Nov 22, 2023
by
djraymond
I
in need of help with mechanical issue!
integraguy05
Oct 2, 2023
3
351
Oct 3, 2023
by
Teg332
Will “DC2” coilovers fit a DC4?
trispoke.
Jul 21, 2023
1
440
Jul 21, 2023
by
MandibleClaW001
T
Ball Joint Boots Ok?
Teg332
Jul 8, 2023
10
657
Jul 9, 2023
by
Teg332
Compliance arm torque specs
Sasaki98
Jun 17, 2023
3
1K
Jun 17, 2023
by
Sasaki98
I want to get better handling out of my 2000 Integra LS
tsp.elijah
May 4, 2023
8
1K
Jun 3, 2023
by
P0sTaL
J
front sway bar upgrade worth it?
jcb595
Jan 25, 2023
10
2K
Apr 9, 2023
by
Sillyver2
9
RS vs other model brake master cylinder
98RSGuy
Feb 28, 2023
1
379
Apr 8, 2023
by
98RSGuy
This Bushing is bad, What is it?
tsp.elijah
Mar 29, 2023
2
862
Mar 29, 2023
by
tsp.elijah
Will the Fortune Auto 500 Series Coilovers fit the DC4?
tsp.elijah
Mar 28, 2023
2
798
Mar 28, 2023
by
Ami
New top hats and bump stops?
B18C1Joe
Dec 18, 2022
4
954
Mar 25, 2023
by
B18C1Joe
Hard race lower front arms?
B18C1Joe
Mar 24, 2023
0
1K
Mar 24, 2023
by
B18C1Joe
Shock tower bushings?
B18C1Joe
Mar 23, 2023
0
303
Mar 23, 2023
by
B18C1Joe
INTEGRA GSR FRONT BAR INSTALL QUESTION.
B18C1Joe
Mar 22, 2023
0
337
Mar 22, 2023
by
B18C1Joe
Brake lockup in seconds, stopping my CV shaft
Wetfeathers
Mar 12, 2023
2
607
Mar 16, 2023
by
Wetfeathers
CV Axle half shaft checklist
Wetfeathers
Feb 20, 2023
6
740
Mar 12, 2023
by
Wetfeathers
A
rear caliper spinning but not compressing
anaveragejoe64
Oct 27, 2022
4
1K
Mar 12, 2023
by
98RSGuy
Half shaft replacement?
Wetfeathers
Mar 2, 2023
0
310
Mar 2, 2023
by
Wetfeathers
Integra dc2 and db6 same subframe?
Dbsan
Mar 2, 2023
0
595
Mar 2, 2023
by
Dbsan
Light pad grind
Wetfeathers
Feb 15, 2023
3
694
Feb 20, 2023
by
Wetfeathers
Billet vs Urethane vs Rubber Shift Linkage Bushings.
junglesalmon1
Jan 3, 2023
2
1K
Jan 4, 2023
by
rguttenb
B
Tein flex Z 97 gsr sedan question
Brunoboy
Oct 30, 2022
9
1K
Nov 3, 2022
by
Brunoboy
Question about adding preload and brake booster delete.
junglesalmon1
Oct 18, 2022
3
1K
Nov 3, 2022
by
junglesalmon1
D
Alignment after lowering my Integra for the first time. Does everything look okay and within spec and anything I should be concerned about.
db7sho
Oct 25, 2022
10
3K
Nov 1, 2022
by
jjkz24
Companies that revalve shocks???
Macncheesefan
Jun 15, 2022
1
510
Oct 27, 2022
by
Ed Sawyer
C
Extremely Aggressive Pull
CorbanB
Aug 30, 2022
2
983
Aug 30, 2022
by
CorbanB
Need advice on if axel is seated properly
Hangry_teg
Jul 23, 2022
12
1K
Aug 2, 2022
by
Silvia
junglesalmon1
Jul 28, 2022
3
1K
Jul 30, 2022
by
Silvia
Break switch replacement problems PLEASE HELP!
Gail
Jun 27, 2022
3
1K
Jun 28, 2022
by
gsrmike2377
need help figuring out best way to get crazy camber
scuffdteg
Jun 7, 2022
5
1K
Jun 26, 2022
by
timoteo
Please Help
jarrett:)
Mar 5, 2022
1
1K
Mar 17, 2022
by
Silvia
Dust Cap Removal
jarrett:)
Mar 11, 2022
1
737
Mar 12, 2022
by
Silvia
Clicking sound
tctech197
Feb 13, 2022
2
794
Feb 14, 2022
by
clinton.lyttle
S
Is the LS/RS stock rear sway bar okay with ITR shocks and springs + LCA for a daily driver?
Supercussion
Feb 4, 2022
1
964
Feb 4, 2022
by
jjkz24
1
1 of 283
Go to page
Go
283
97.2K
posts
20.7M
views
Way's to improve your Teg's handling and stopping power
Show Less
Join Community
Grow Your Business
Forum Staff
View All
dpaton
jjkz24
Administrator
Administrator
Administrator
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Classic JDM cars and motorcycles.
140+ members
Home
Forums
Technical / Help
